Résolu
probleme d installation de minecraft
Dernière réponse : dans Jeux et consoles
Partagez
bonjour, j'ai voulu installer minecraft sur mon pc puis sa m affiche ceci:
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 19/04/12 23:19
Minecraft: Minecraft 1.2.5
OS: Windows 7 (x86) version 6.1
Java: 1.6.0_31, Sun Microsystems Inc.
VM: Java HotSpot(TM) Client VM (mixed mode), Sun Microsystems Inc.
LWJGL: 2.4.2
[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:185)
at org.lwjgl.opengl.Display.createWindow(Display.java:311)
at org.lwjgl.opengl.Display.create(Display.java:856)
at org.lwjgl.opengl.Display.create(Display.java:784)
at org.lwjgl.opengl.Display.create(Display.java:765)
at net.minecraft.client.Minecraft.a(SourceFile:236)
at net.minecraft.client.Minecraft.run(SourceFile:657)
at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT d416610d ----------
Autres pages sur : probleme installation minecraft
Et mets à jour Java aussi.
  • MagicVitalic a sélectionné cette solution comme la meilleure réponse
Posez votre question
