Carte graphique avec ma config actuelle?
Voila ma config (PC de chez Auchan de début d'année
Carte mère
SMBios version 2.3
NEC COMPUTERS INTERNATIONAL MS-7168 1.0
Bios: American Megatrends Inc. 080012 09/06/2005 taille:512kb
Processeur
AMD Athlon(tm) 64 Processor 3400+ (2188Mhz) (L1:128ko L2:512ko )
Mémoire
Barette de 512Mo 400Mhz Manufacturer0
Barette de 512Mo 400Mhz Manufacturer1
mémoire windows (cette valeur ne correspond pas exactement à la mémoire totale physique): 895Mo
Péripheriques IDE
ST3200826AS 3.03 186.00Go(tampon:8 Mo)
Lecteurs CD/DVD
_NEC DVD_RW ND-3550A
Disque dur
ST3200826AS (186.31Go)
Generic USB CF Reader USB Device
Generic USB MS Reader USB Device
Generic USB SD Reader USB Device
Generic USB SM Reader USB Device
Cartes PCI/AGP
Bus Series
VIA Technologies, Inc.:IEEE 1394 Host Controller
ATI Technologies Inc:IXP SB400 SMBus Controller
ATI Technologies Inc:IXP SB400 USB2 Host Controller
ATI Technologies Inc:IXP SB400 USB Host Controller
Ponts
Advanced Micro Devices [AMD]:K8 [Athlon64/Opteron] Miscellaneous Control
Advanced Micro Devices [AMD]:K8 [Athlon64/Opteron] DRAM Controller
Advanced Micro Devices [AMD]:K8 [Athlon64/Opteron] Address Map
Advanced Micro Devices [AMD]:K8 [Athlon64/Opteron] HyperTransport Technology Configuration
ATI Technologies Inc:IXP SB400 PCI-PCI Bridge
ATI Technologies Inc:IXP SB400 PCI-ISA Bridge
Page 1
ATI Technologies Inc:RS480 PCI Bridge
ATI Technologies Inc:RS480 Host Bridge
Multimedia
ATI Technologies Inc:IXP SB400 AC'97 Audio Controller
Affichage
ATI Technologies Inc:RS480 [Radeon Xpress 200G Series]
Réseau
Realtek Semiconductor Co., Ltd.:RTL-8139/8139C/8139C+
Stockage
ATI Technologies Inc:Standard Dual Channel PCI IDE Controller ATI
ATI Technologies Inc:ATI 4379 Serial ATA Controller
ATI Technologies Inc:ATI 437A Serial ATA Controller
Périphérique USB
Alcor Micro Corp. USB Reader
Clavier
Clavier standard 101/102 touches ou clavier Microsoft Natural Keyboard PS/2
Souris
Souris Microsoft PS/2
Ecran(s)
Écran par défaut
A priori, config pas trop mauvaise mais je voudrais changer la carte graphique. Laquelle prendre pour pouvoir jouer aux jeux récents?
A part ça que me conseillez vous de changer tout en restan dans un budget correcte?
Merci d'avance
Autres pages sur : carte graphique config actuelle
jonathan2b a dit :
c'est un 250W.
Faut-il changer l'alim pour avoir un meilleur PC?
C'est pas juste histoire d'avoir un meilleur PC, mais il y a fort à parier que la puissance de 250W ne sera pas suffisante pour alimenter ta nouvelle carte graphique.
Le conseil que 99% des gens te donneront ici : Fortron Green Power 400W...
+1 Forton...
Et pour la cg, une tite 7600GT rentre ds ton budget :D
