decripter un minidump de plus svp
Microsoft (R) Windows Debugger Version 6.4.0007.2
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [D:\Telechargement\Mini021507-02.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 1) UP Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0x804d4000 PsLoadedModuleList = 0x8054be30
Debug session time: Thu Feb 15 19:50:15.718 2007 (GMT+1)
System Uptime: 0 days 0:21:27.320
Loading Kernel Symbols
Loading unloaded module list
Loading User Symbols
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck D1, {8, 2, 0, f781937a}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
Unable to load image usbehci.sys, Win32 error 2
*** WARNING: Unable to verify timestamp for usbehci.sys
*** ERROR: Module load completed but symbols could not be loaded for usbehci.sys
Probably caused by : usbehci.sys ( usbehci+237a )
Followup: MachineOwner
Autres pages sur : decripter minidump svp
"et quand tu joues a des jeux (utilisant de la 3D) tu as le meme probleme ? "
Je ne fait pas de jeux avec celui ci. En fait je m en sers comme hptc pour musique divx et photos
"et sinon tu n'avais pas repondu: tu as essayé avec un autre lecteur audio/video que celui que tu utilises la?"
C est vrai que je n ai pas essayé ave un autre lecteur, j utilise foobar2000 et mpc.
Est ce que ca pourrait etre une surchauffe dans la tour, du processeur par exemple, et que ma carte se met en securité et donc redemarre l ordi?
Apparament le fichier n est pas d une tres grande utilité?
