Coucou,
Quand je lance partition magic 7, j'ai le droit a un msg d'erreur sans pouvoir entrer dans le programme "init failed: error 117" "Partition's drive letter cannot be identified".
Alors je me dis, tant pis, je vais installer redhat 9.1, p-e qu'au cours de l'installation, je pourrais repartitionner, bien non, il me dit qu'il y a un problème au niveau de la géométrie du disque, et qu'il faut aller voir dans le bios..
Bref, je retourne ds windows et lance "partition info" de powerquest et voilà que j'ai un msg :
"Disk geometry error(s) were detected on this drive."
et voilà ensuite ce qu'il me met:
General System Information:
Total Physical Memory (bytes): 267,878,400
Used Physical Memory: (bytes): 164,421,632
Maximum Page File Size: (bytes): 648,720,384
Current Page File Size: (bytes): 117,833,728
Disk Geometry Information for Disk 1: 4865 Cylinders, 255 Heads, 63 Sectors/Track
System PartSect # Boot BCyl Head Sect FS ECyl Head Sect StartSect NumSects
0 0 80 0 1 1 07 636 254 63 63 10,233,342
0 1 00 637 0 1 0F 1023 144 63 10,233,405 67,931,955
Info: Begin C,H,S values were large drive placeholders.
Info: End C,H,S values were large drive placeholders.
Actual values are:
0 1 00 637 0 1 0F 4865 144 63 10233405 67931955
Error #109: Partition ends after end of disk.
ucEndCylinder (4865) must be less than 4865.
Info: Partition didn't end on cylinder boundary.
ucEndHead expected to be 254, not 144.
10,233,405 0 00 637 1 1 07 1023 254 63 10,233,468 61,496,757
Actual values are:
10233405 0 00 637 1 1 07 4464 254 63 10233468 61496757
Partition Information for Disk 1: 38,162.2 Megabytes
Volume PartType Status Size MB PartSect # StartSect TotalSects UsedSects FreeSects
C: NTFS Pri,Boot 4,996.7 0 0 63 10,233,342 10,233,342 0
ExtendedX Pri 33,169.9 0 1 10,233,405 67,931,955 61,505,955 6,426,000
EPBR Log 30,027.7 None -- 10,233,405 61,496,820 61,496,820 0
D: NTFS Log 30,027.7 10,233,405 0 10,233,468 61,496,757 61,496,757 0
Unallocated Log 3,137.7 None -- 71,730,225 6,426,000 0 6,426,000
Boot Record for drive C: (Drive: 1, Starting sector: 63, Type: NTFS)
1. Jump: EB 52 90
2. OEM Name: NTFS
3. Bytes per Sector: 512
4. Sectors per Cluster: 8
5. Reserved Sectors: 0
6. Number of FATs: 0
7. Root Dir Entries: 0
8. Total Sectors: 0
9. Media Descriptor: 0xF8
10. Sectors per FAT: 0
11. Sectors per Track: 63 (0x3F)
12. Number of Heads: 255 (0xFF)
13. Hidden Sectors: 63 (0x3F)
14. Total Sectors (>32MB): 0 (0x0)
15. Unused: 0x80008000
16. Total NTFS Sectors: 10233341
17. MFT Start Cluster: 262144
18. MFT Mirror Start Clust: 639583
19. Clusters per FRS: 246
20. Clusters per Index Blk: 1
21. Serial Number: 0xE644ECDD44ECB20B
22. Checksum: 0 (0x0)
23. Boot Signature: 0xAA55
Boot Record for drive D: (Drive: 1, Starting sector: 10,233,468, Type: NTFS)
1. Jump: EB 52 90
2. OEM Name: NTFS
8. Total Sectors: 0
16. Total NTFS Sectors: 61496756
17. MFT Start Cluster: 4
18. MFT Mirror Start Clust: 4245172
21. Serial Number: 0x9230C6AD30C6981D
Windows XP fonctionne sans problème (avec quelque bugs), je lance un scandisk. Le pc reboot, et le scandisk se fait parfaitement, il trouve juste quelque erreurs sur des fichiers.
Si quelqu'un pouvait me dire ou se trouve le problème, et si je peux faire quelque chose merci ^^.
