Ecran bleu de la mort
j'ai un problème d'écran bleu et d'erreur minidump.
Voici le lien du dernier fichier dmp : http://www.yousendit.com/download/TzY2WUhwMGs0b0JMWEE9P...
Et voici le rapport de windbg:
Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\Mini112309-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: srv*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6001 (Service Pack 1) MP (3 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 6001.18304.x86fre.vistasp1_gdr.090805-0102
Machine Name:
Kernel base = 0x8204e000 PsLoadedModuleList = 0x82165c70
Debug session time: Mon Nov 23 04:25:30.260 2009 (GMT+1)
System Uptime: 0 days 5:49:00.196
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Unable to load image \SystemRoot\system32\DRIVERS\sis163u.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for sis163u.sys
*** ERROR: Module load completed but symbols could not be loaded for sis163u.sys
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000007E, {c0000005, 8f224522, 8c60bc24, 8c60b920}
Probably caused by : sis163u.sys ( sis163u+17522 )
Followup: MachineOwner
1: kd> !analyze -v
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003. This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG. This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG. This will let us see why this breakpoint is
happening.
Arguments:
Arg1: c0000005, The exception code that was not handled
Arg2: 8f224522, The address that the exception occurred at
Arg3: 8c60bc24, Exception Record Address
Arg4: 8c60b920, Context Record Address
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - L'instruction 0x%08lx emploie l'adresse m moire 0x%08lx. La m moire ne peut pas tre en tat
FAULTING_IP:
sis163u+17522
8f224522 8b484f mov ecx,dword ptr [eax+4Fh]
EXCEPTION_RECORD: 8c60bc24 -- (.exr 0xffffffff8c60bc24)
ExceptionAddress: 8f224522 (sis163u+0x00017522)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 00000000
Parameter[1]: 0000004f
Attempt to read from address 0000004f
CONTEXT: 8c60b920 -- (.cxr 0xffffffff8c60b920)
eax=00000000 ebx=8726000c ecx=86bb63a0 edx=8c60bca4 esi=86bb5000 edi=00000000
eip=8f224522 esp=8c60bcec ebp=8c60bd00 iopl=0 nv up ei pl zr na pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010246
sis163u+0x17522:
8f224522 8b484f mov ecx,dword ptr [eax+4Fh] ds:0023:0000004f=????????
Resetting default scope
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
CURRENT_IRQL: 0
ERROR_CODE: (NTSTATUS) 0xc0000005 - L'instruction 0x%08lx emploie l'adresse m moire 0x%08lx. La m moire ne peut pas tre en tat
EXCEPTION_PARAMETER1: 00000000
EXCEPTION_PARAMETER2: 0000004f
READ_ADDRESS: GetPointerFromAddress: unable to read from 82185868
Unable to read MiSystemVaType memory at 82165420
0000004f
FOLLOWUP_IP:
sis163u+17522
BUGCHECK_STR: 0x7E
DEFAULT_BUCKET_ID: NULL_CLASS_PTR_DEREFERENCE
LAST_CONTROL_TRANSFER: from 8f22489f to 8f224522
STACK_TEXT:
WARNING: Stack unwind information not available. Following frames may be wrong.
8c60bd00 8f22489f 00000000 0026000c 8726000c sis163u+0x17522
8c60bd18 8f2301c6 86bb5000 8726000c 8726000c sis163u+0x1789f
8c60bd38 8f20e935 00bb5000 00000060 40000100 sis163u+0x231c6
8c60bd58 8f20f7ac 00000006 00000000 00000000 sis163u+0x1935
8c60bd7c 82223b22 86dd8000 d3252dd5 00000000 sis163u+0x27ac
8c60bdc0 8207ca2e 8f20f4bc 86dd8000 00000000 nt!PspSystemThreadStartup+0x9d
00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x16
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: sis163u+17522
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: sis163u
IMAGE_NAME: sis163u.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4588ab7f
STACK_COMMAND: .cxr 0xffffffff8c60b920 ; kb
FAILURE_BUCKET_ID: 0x7E_sis163u+17522
1: kd> lmvm sis163u
start end module name
8f20d000 8f242200 sis163u T (no symbols)
Loaded symbol image file: sis163u.sys
Image path: \SystemRoot\system32\DRIVERS\sis163u.sys
Image name: sis163u.sys
Timestamp: Wed Dec 20 04:18:23 2006 (4588AB7F)
CheckSum: 0003EC1A
ImageSize: 00035200
Translations: 0000.04b0 0000.04e4 0409.04b0 0409.04e4
Voilà, je suis arrivé à faire fonctionner windbg tant bien que mal, en suivant des tutos mais maintenant je sais plus quoi faire; sachant que le pilote en défaut (sis163u.sys) est à jour. Il s'agit du pilote de ma carte réseau sans fil (802.11 USB Wireless LAN Adapter)
Pourriez-vous me donner votre avis et me dire ce qu'il faut faire.
Merci d'avance pour votre aide!
Autres pages sur : ecran bleu mort
Merci thor37230 et the_wisard pour vos réponses rapides.
t'a essayé de mettre à jour le pilote de cette carte réseau sans fil?
oui, dans le gestionnaire de périphérique/ propriétés de la carte réseau... le pilote est à jour!
Un coup de CCclean et nouveau driver je dirais.
j'ai fait le nettoyage avec CClean, tout est ok.
Je n'ai pas trouvé de meilleur pilote.
En plus j'ai un nouveau écran bleu mais cette fois provoqué par afd.sys. Pour ce soir j'ai pas envie de refaire toutes les manipulations que j'ai faites cet apres midi pour sis163u.sys, alors je verrais demain.
Si quelqu'un peut m'aider a régler ce problème parceque ca devient pénible ces redémarrage intempestifs du pc.
Merci pour votre aide
thor37230 a dit :
tu peux nous détailler toute ta config
Bonjour Thor,
voici ma configuration PC:
Processeur AMD Phenom(tm) 8450 Triple - Core Processor
Mémoire vive 3,00Go
Graphiques NVIDIA GeForce 9300 GE
Graphiques de jeu 1535 Mo total de mémoire vidéo disponible
Disque dur principal 27GB libre (323GB au total)
Windows Vista (TM) Home Premium
Système:
Fabricant Packard Bell BV
Modèle MCP78PVM - PM
Quantité totale de mémoire système Mémoire vive 3,00Go
Type du système Système d ’ exploitation 32bits
Nombre de cœurs de processeur 3
Compatible 64bits Oui
Stockage:
Taille totale des disques durs 323Go
Partition de disque (C: ) 27Go libre (323Go au total)
Lecteur multimédia (D: ) CD/DVD
Graphiques:
Afficher le type de carte: NVIDIA GeForce 9300 GE
Mémoire graphique totale disponible 1535Mo
-Mémoire graphique dédiée 256Mo
-Mémoire système dédiée 0Mo
-Mémoire système partagée 1279Mo
Afficher la version du pilote de la carte: 7.15.11.7490
Résolution du moniteur principal 1280x960
Version DirectX DirectX 10
Réseau:
Carte réseau Realtek PCIe FE Family Controller
Carte réseau 802.11 USB Wireless LAN Adapter
Carte réseau Carte miniport Microsoft Tun
Voilà, j'espere avoir tout mis.
Merci pour ton aide
leboloco a dit :
hello
j'ai lu en haut du rapport sp1...(23/11/09)
tu n'a pas le sp2 ?
peu t'etre une maj windows regle ça...
c'est possible, seulement je n'ai jamais réussi à installer cette mise à jour.
A chaque fois que je la fait il y a échec!
Et windows ne trouve pas de solution à ce problème.
Merci pour ton aide
Alors voilà, je ne sait pas comment désinstaller le SP1.
je vous met la liste des programmes et des mises à jour installés sur mon PC; pouvez vous me dire quelle(s) ligne(s) je dois désinstaller?
Il y a peut etre quelques fautes dans cette liste parceque pour pas avoir à la recopier (le copier coller ne marchait pas dans cette liste), j'ai fait des captures d'ecran puis des reconnaissances d'ecritures. J'ai corrigé la plus part mais il se peut qu'il en reste.
Voici les programmes installé:
Adobe Flash Player 10 ActiveX Adobe Systems Incorporated 11/11/2009
Adobe Reader 9.13 - Français Adobe Systems Incorporated 23/08/2009
Akeo - Kit de connexion Neuf 22/08/2009 10,8 Mo
ArcSoft Photolmpression 05/10/2009 2,28 Mo
Assistant de connexion Windows Live Microsoft Corporation 05/03/2009 1,93 Mo
Avira AntiVir Personal - Free Antivirus Avira GmbH 11/11/2009 77,4 Mo
Carbonite 23/08/2008 300Ko
CCleaner (remove only) Piriform 23/08/2009 2,62 Mo
CDBumerXP CDBurnerXP 22/08/2009 6,52 Mo
Debugging Tools for Windows (x86) Microsoft Corporation 23/11/2009 38,5 Mo
EPSON Copy Utihty 05/10/2009 1,16 Mo
EPSON Logiciel imprimante 05/10/2009
EPSON Photo Print 05/10/2009 2,52 Mo
EPSON PhotoQuicker3.2 05/10/2009 26,3 Mo
EPSON Smart Panel 05/10/2009 1,09 Mo
GoogleBAE 23/08/2008
Google Chrome Google Inc. 13/08/2009 59,4 Mo
Google Earth 23/08/2008 32,0 Mo
GoogleDesktop 23/08/2008
GoogleToolbar 23/08/2008
HDReg France Acxiom 03/06/2008 4,59 Mo
HijackThis 2.0.2 TrendMicro 11/11/2009 400 Ko
HiVo IncrediMail 14/04/2009 2,54 Mo
Infocentre Rev. 2.0 23/08/2008 38,7 Mo
Installation Windows Live Microsoft Corporation 18/11/2009 43,8 Mo
Java(TM) 6 Update 15 Sun Microsystems, Inc. 29/11/2008 94,3 Mo
L&H TTS3000 Français 13110/2009
Logiciel darchivage WInRAR 30/08/2009 3,81 Mo
Maiwarebytes Anti-Maiware Malwarebytes Corporation 11/11/2009 3,99 Mo
Metaboli 23/08/2008
Microsoft .NET Framework 3.5 SP1 Microsoft Corporation 15/02/2009 36,9 Mo
Microsoft Visual C++ 2005 ATL Update kb973923 - x86 8.0.50727.4053 Microsoft Corporation 30/07/2009 251 Ko
Microsoft Visual C++ 2008 ATL Update kb973924 - x86 9.030729.4148 Microsoft Corporation 13/11/2009 199 Ko
Microsoft Visual C++ 2008 Redistributable - 6 9.0.30729.17 Microsoft Corporation 11/11/2009 590 Ko
Microsoft Works 9 SE 23/08/2008 141 Mo
Microsoft! Office Trial 2007 23/08/2008 260 Mo
Module linguistique Microsoft .NET Framework 3.5 SP1 - fra Microsoft Corporation 17/02/2009 36,9 Mo
MSXML 4.0 SP2 (KB936181) Microsoft Corporation 26/08/2008 126 Mo
MSXML 4.0 SP2 (KB941833) Microsoft Corporation 28/08/2008 126 Mo
MSXML 4.0 SP2 (KB954430) Microsoft Corporation 13/11/2008 127 Mo
Olympus Digital Wave Player 06/10/2009 112 Mo
Outil de téléchargement Windows Live Microsoft Corporation 18/11/2009 225 Ko
Packard Bell ImageWriter 23/0812008 138 Mo
Packard Bell LCD Test 23/08/2008 138 Mo
Packard Bell Updator 23/08/2008 138 Mo
Picasa2 23/08/2008
Picasa 3 Google, Inc. 12/11/2009 74,5 Mo
Programme de gestion Camera de Logitech! 14/11/2009 13,3 Mo
Quizz ABC 1.0 AKEO 13/10/2009 6,80 Mo
Realtek Ethernet Controller Driver For Windows Vista and Later 12/11/2009 1,79 Mo
Realtek HD Audio V6.0.1.5559 23/08/2008
ScanToWeb 05/10/2009 2,17 Mo
SetUp My PC 23/08/2008
SFR- Media Center SFR 27/09/2009 671 Mo
Spybot - Search & Destroy Safer Networking Limited 23/08/2009 55,6 Mo
Video NVIDIA v174.90 23/08/2008 66,4 Mo
VLC media player 1.03 VideoLAN Team 11/11/2009 32,8 Mo
Windows Driver Package - Silicon Integrated Systems Corp.(1.09b.01) (SIS163u) Net (11/20/2006 6.0.1039.1092) 23/08/2008
Windows Live OneCare safety scanner 23/08/2009 43,4 Mo
... et voici les mises à jour installées:
Adobe Reader 9.1.3 - CPSID_49522 Adobe Reader9.1.3 ... Adobe Systems Incorporated 23/08/2009
Correctif logiciel pour Microsoft Windows (KB946084) Microsoft Windows Microsoft Corporation 03/06/2008
Correctif logiciel pour Microsoft Windows (KB947880) Microsoft Windows Microsoft Corporation 03/06/2008
Correctif logiciel pour Microsoft Windows (KB952287) Microsoft Windows Microsoft Corporation 26/08/2008
Cumulative Update for Media Center for Windows Vista (K8955519) Microsoft Windows Microsoft Corporation 23/10/2008
Cumulative Update for Media Center for Windows Vista (KB960544) Microsoft Windows Microsoft Corporation 16/02/2009
Cumulative Update for Media Center for Windows Vista (KB967632) Microsoft Windows Microsoft Corporation 14/06/2009
Cumulative Update for Media Center for Windows Vista (KB974306) Microsoft Windows Microsoft Corporation 16/10/2009
Hotfix for Microsoft .NET Framework 3.5 Sp1 (KB953595) Microsoft .NET Fra... Microsoft Corporation 15/02/2009
Hotfix for Microsoft .NET Framework 3.5 Sp1 (KB958484) Microsoft .NET Fra... Microsoft Corporation 15/02/2009
Microsoft Office 2007 Service Pack 2 (SP2) Microsoft Office Ho... Microsoft 11/11/2009
Mise à jour de sécurité pour Microsoft Windows (KB938464) Microsoft Windows Microsoft Corporation 11/0912008
Mise à jour de sécurité pour Microsoft Windows (KB941693) Microsoft Windows Microsoft Corporation 03/06/2008
Mise à jour de sécurité pour Microsoft Windows (KB947864) Microsoft Windows Microsoft Corporation 03/0612008
Mise à jour de sécurité pour Microsoft Windows (KB948590) Microsoft Windows Microsoft Corporation 03/06/2008
Mise à jour de sécurité pour Microsoft Windows (KB948881) Microsoft Windows Microsoft Corporation 03/06/2008
Mise à jour de sécurité pour Microsoft Windows (KB950582) Microsoft Windows Microsoft Corporation 26/08/2008
Mise à jour de sécurité pour Microsoft Windows (KB950762) Microsoft Windows Microsoft Corporation 26108/2008
Mise à jour de sécurité pour Microsoft Windows (KB950974) Microsoft Windows Microsoft Corporation 26/08/2008
Mise à jour de sécurité pour Microsoft Windows (KB951066) Microsoft Windows Microsoft Corporation 26/08/2008
Mise à jour de sécurité pour Microsoft Windows (K895i376) Microsoft Windows Microsoft Corporation 26/08/2008
Mise à jour de sécurité pour Microsoft Windows (KB95i698) Microsoft Windows Microsoft Corporation 26/08/2008
Mise à jour de sécurité pour Microsoft Windows (KB952004) Microsoft Windows Microsoft Corporation 17/04/2009
Mise à jour de sécurité pour Microsoft Windows (K8952069) Microsoft Windows Microsoft Corporation 12112/2008
Mise à jour de sécurité pour Microsoft Windows (KB953i55) Microsoft Windows Microsoft Corporation 30/10/2008
Mise à jour de sécurité pour Microsoft Windows (KB953733) Microsoft Windows Microsoft Corporation 26/08/2008
Mise a jour de sécurte pour Microsoft Windows (K6953838) Microsoft Windows Microsoft Corporation 26/08/2.008
Mise à jour de sécurité pour Microsoft Windows (KB953839) Microsoft Windows Microsoft Corporation 26/08/2008
Mise à jour de sécurité pour Microsoft Windows (KB954154) Microsoft Windows Microsoft Corporation 11/09/2008
Mise à jour de sécurité pour Microsoft Windows (KB954i55) Microsoft Windows Microsoft Corporation 16/10/2009
Mise à jour de sécurité pour Microsoft Windows (KB954211) Microsoft Windows Microsoft Corporation 16110/2008
Mise à jour de sécurité pour Microsoft Windows (KB954459) Microsoft Windows Microsoft Corporation 13/ii/2008
Mise à jour de sécurité pour Microsoft Windows (KB955069) Microsoft Windows Microsoft Corporation 13/ii/2008
Mise à jour de sécurité pour Microsoft Windows (KB95630) Microsoft Windows Microsoft Corporation 16/10/2008
Mise à jour de sécurité pour Microsoft Windows (1(8956391) Microsoft Windows Microsoft Corporation 16/10/2008
Mise à jour de sécurité pour Microsoft Windows (K8956572) Microsoft Windows Microsoft Corporation 17/04/2009
Mise à jour de sécurité pour Microsoft Windows (KB956744) Microsoft Windows Microsoft Corporation 14/08/2009
Mise à jour de sécurité pour Microsoft Windows (KB956802) Microsoft Windows Microsoft Corporation 12/12/2008
Mise à jour de sécurité pour Microsoft Windows (K8956841) Microsoft Windows Microsoft Corporation 16110/2008
Mise à jour de sécurité pour Microsoft Windows (1(8957095) Microsoft Windows Microsoft Corporation 16/10/2008
Mise à jour de sécurité pour Microsoft Windows (KB957097) Microsoft Windows Microsoft Corporation 13111/2008
Mise à jour de sécurité pour Microsoft Windows (1(8958215) Microsoft Windows Microsoft Corporation 12/12/2008
Mise à jour de sécurité pour Microsoft Windows (1(8958623) Microsoft Windows Microsoft Corporation 12/12/2008
Mise à jour de sécurité pour Microsoft Windows (1(8958624) Microsoft Windows Microsoft Corporation 12/12/2008
Mise à jour de sécurité pour Microsoft Windows (KB958644) Microsoft Windows Microsoft Corporation 24110/2008
Mise à jour de sécurité pour Microsoft Windows (KB958687) Microsoft Windows Microsoft Corporation 15/01/2009
Mise à jour de sécurité pour Microsoft Windows (1(8958690) Microsoft Windows Microsoft Corporation 12/03/2009
Mise à jour de sécurité pour Microsoft Windows (1(8958869) Microsoft Windows Microsoft Corporation 16/10/2009
Mise à jour de sécurité pour Microsoft Windows (1(8959426) Microsoft Windows Microsoft Corporation 17/04/2009
Mise à jour de sécurité pour Microsoft Windows (1(8960225) Microsoft Windows Microsoft Corporation 12/03/2009
Mise à jour de sécurité pour Microsoft Windows (1(8960714) Microsoft Windows Microsoft Corporation 18/12/2008
Mise à jour de sécurité pour Microsoft Windows (1(8960715) Microsoft Windows Microsoft Corporation 12/02/2009
Mise à jour de sécurité pour Microsoft Windows (1(8960803) Microsoft Windows Microsoft Corporation 17/04/2009
Mise à jour de sécurité pour Microsoft Windows (K8961260) Microsoft Windows Microsoft Corporation 12/02/2009
Mise à jour de sécurité pour Microsoft Windows (1(8961371) Microsoft Windows Microsoft Corporation 16/07/2009
Mise à jour de sécurité pour Microsoft Windows (1(8961501) Microsoft Windows Microsoft Corporation 12/06/2009
Mise à jour de sécurité pour Microsoft Windows (1(8963027) Microsoft Windows Microsoft Corporation 17/04/2009
Mise à jour de sécurité pour Microsoft Windows (1(8967723) Microsoft Windows Microsoft Corporation 12/09/2009
Mise à jour de sécurité pour Microsoft Windows (1(8968537) Microsoft Windows Microsoft Corporation 12/06/2009
Mise à jour de sécurité pour Microsoft Windows (1(8968816) Microsoft Windows Microsoft Corporation 12/09/2009
Mise à jour de sécurité pour Microsoft Windows (1(8969897) Microsoft Windows Microsoft Corporation 12/06/2009
Mise à jour de sécurité pour Microsoft Windows (1(8969898) Microsoft Windows Microsoft Corporation 12/06/2009
Mise à jour de sécurité pour Microsoft Windows (K8969947) Microsoft Windows Microsoft Corporation 11111/2009
Mise à jour de sécurité pour Microsoft Windows (1(8970238) Microsoft Windows Microsoft Corporation 12/06/2009
Mise à jour de sécurité pour Microsoft Windows (K8970710) Microsoft Windows Microsoft Corporation 12109/2009
Mise à jour de sécurité pour Microsoft Windows (1(8971486) Microsoft Windows Microsoft Corporation 16/10/2009
Mise à jour de sécurité pour Microsoft Windows (K8971557) Microsoft Windows Microsoft Corporation 14/08/2009
Mise à jour de sécurité pour Microsoft Windows (KB971657) Microsoft Windows Microsoft Corporation 14/0812009
Mise à jour de sécurité pour Microsoft Windows (KB971961) Microsoft Windows Microsoft Corporation 10/09/2009
Mise à jour de sécurité pour Microsoft Windows (KB972260) Microsoft Windows Microsoft Corporation 30/07/2009
Mise àjour de sécurité pour Microsoft Windows (KB973346) Microsoft Windows Microsoft Corporation 16/07/2009
Mise à jour de sécurité pour Microsoft Windows (KB973507) Microsoft Windows Microsoft Corporation 14/08/2009
Mise àjour de sécurité pour Microsoft Windows (KB973525) Microsoft Windows Microsoft Corporation 16/10/2009
Mise à jour de sécurité pour Microsoft Windows (KB973540) Microsoft Windows Microsoft Corporation 14/08/2009
Mise à jour de sécurité pour Microsoft Windows (KB973565) Microsoft Windows Microsoft Corporation 11/11/2009
Mise àjour de sécurité pour Microsoft Windows (KB974455) Microsoft Windows Microsoft Corporation 16/10/2009
Mise à jour de sécurité pour Microsoft Windows (KB974469) Microsoft Windows Microsoft Corporation 16/10/2009
Mise à jour de sécurité pour Microsoft Windows (KB974571) Microsoft Windows Microsoft Corporation 16/10/2009
Mise àjour de sécurité pour Microsoft Windows (KB975467) Microsoft Windows Microsoft Corporation 16/10/2009
Mise àjour de sécurité pour Microsoft Windows (KB975517) Microsoft Windows Microsoft Corporation 16/10/2009
Mise à jour Microsoft Office Excel 2007 Help (KB963678) Microsoft Office Ho... Microsoft 01/08/2009
Mise à jour Microsoft Office Powerpoint 2007 Help (KB963669) Microsoft Office Ho... Microsoft 01/08/2009
Mise à jour Microsoft Office Word 2007 Help (KB963665) Microsoft Office Ho... Microsoft 01/08/2009
Mise àjour pour Microsoft Windows (KB905866) Microsoft Windows Microsoft Corporation 11/11f200
Mise à jour pour Microsoft Windows (KB935509) Microsoft Windows Microsoft Corporation 21/01/2008
Mise à jour pour Microsoft Windows (KB937286) Microsoft Windows Microsoft Corporation 03/06/2008
Mise àjour pour Microsoft Windows (KB937287) Microsoft Windows Microsoft Corporation 21/01/2008
Mise àjour pour Microsoft Windows (KB938371) Microsoft Windows Microsoft Corporation 03/06/2008
Mise à jour pour Microsoft Windows (KB947562) Microsoft Windows Microsoft Corporation 26/08/2008
Mise à jour pour Microsoft Windows (KB948609) Microsoft Windows Microsoft Corporation 16/02/2009
Mise à jour pour Microsoft Windows (KB948610) Microsoft Windows Microsoft Corporation 16/02/2009
Mise à jour pour Microsoft Windows (KB949246) Microsoft Windows Microsoft Corporation 16/02/2009
Mise à jour pour Microsoft Windows (KB949247) Microsoft Windows Microsoft Corporation 16/02/2009
Mise ajour pour Microsoft Windows (K6950124) Microsoft Windows Microsoft Corporation 2b108/2008
Mise à jour pour Microsoft Windows (KB950125) Microsoft Windows Microsoft Corporation 26/08/2008
Mise à jour pour Microsoft Windows (K8950126) Microsoft Windows Microsoft Corporation 26/08/2008
Mise à jour pour Microsoft Windows (KB951072) Microsoft Windows Microsoft Corporation 26/08/2008
Mise à jour pour Microsoft Windows (K8951618) Microsoft Windows Microsoft Corporation 26/08/2008
Mise à jour pour Microsoft Windows (KB951978) Microsoft Windows Microsoft Corporation 26/08/2008
Mise à jour pour Microsoft Windows (KB952709) Microsoft Windows Microsoft Corporation 26/08/2008
Mise à jour pour Microsoft Windows (K8954366) Microsoft Windows Microsoft Corporation 11/09/2008
Mise à jour pour Microsoft Windows (K8955020) Microsoft Windows Microsoft Corporation 26/08/2008
Mise à jour pour Microsoft Windows (KB955302) Microsoft Windows Microsoft Corporation 11109/2008
Mise à jour pour Microsoft Windows (K8955430) Microsoft Windows Microsoft Corporation 04105/2009
Mise à jour pour Microsoft Windows (KB955839) Microsoft Windows Microsoft Corporation 12/12/2008
Mise à jour pour Microsoft Windows (KB957200) Microsoft Windows Microsoft Corporation 30/10/2008
Mise à jour pour Microsoft Windows (KB957321) Microsoft Windows Microsoft Corporation 27/11/2008
Mise à jour pour Microsoft Windows (KB957388) Microsoft Windows Microsoft Corporation 12/12/2008
Mise à jour pour Microsoft Windows (KB958481) Microsoft Windows Microsoft Corporation 16/02/2009
Mise à jour pour Microsoft Windows (KB958483) Microsoft Windows Microsoft Corporation 16/02/2009
Mise à jour pour Microsoft Windows (KB959108) Microsoft Windows Microsoft Corporation 27/11/2008
Mise à jour pour Microsoft Windows (KB959130) Microsoft Windows Microsoft Corporation 27/11/2008
Mise à jour pour Microsoft Windows (KB959772) Microsoft Windows Microsoft Corporation 12/03/2009
Mise à jour pour Microsoft Windows (KB968389) Microsoft Windows Microsoft Corporation 22)/2009
Mise à jour pour Microsoft Windows (KB970653) Microsoft Windows Microsoft Corporation 29/08/2009
Mise à jour pour Microsoft Windows (K8972036) Microsoft Windows Microsoft Corporation 05)09/2009
Mise à jour pour Microsoft Windows (KB972145) Microsoft Windows Microsoft Corporation 28/10/2009
Mise à jour pour Microsoft Windows (K8973768) Microsoft Windows Microsoft Corporation 10/09/2009
Mise à jour pour Microsoft Windows (KB976749) Microsoft Windows Microsoft Corporation 05111/2009
Security Update for 2007 Microsoft Office System (KB969559) Microsoft Office Ho... Microsoft 11/11/2009
Security Update for 2007 Microsoft Office System (KB973704) Microsoft Office Ho... Microsoft 1111112009
Security Update for Microsoft Office Excel 2007 (KB973593) Microsoft Office Ho... Microsoft 11/11/2009
Security Update for Microsoft Office PowerPoint 2007 (KB957789) Microsoft Office Ho... Microsoft 11/11/2009
Security Update for Microsoft Office system 2007 (972581) Microsoft Office Ho... Microsoft 11f11/2009
Security Update for Microsoft Office system 2007 (KB969613) Microsoft Office Ho... Microsoft 11/1112009
Security Update for Microsoft Office system 2007 (KB974234) Microsoft Office Ho... Microsoft 11/11/2009
Security Update for Microsoft Office Visio Viever 2007 (KB973709) Microsoft Office Ho... Microsoft 11/11/2009
Update for 2007 Microsoft Office System (KB967642) Microsoft Office Ho... Microsoft 11/11/2009
Update for Microsoft .NET Framework 33 spi (KB963707) Microsoft .NET Fra... Microsoft Corporation 01/08/2009
Update for Microsoft Office Word 2007 (KB974561) Microsoft Office Ho... Microsoft 11/11/2009
Windows Search 4.0 Microsoft Windows Microsoft Corporation 26/08/2008
