ecran bleu- probleme memoire?
voila j'ai eu plusieurs crash (ecran bleu), j'ai ouvert le fichier DUMP (avec WINDBG) , et il m'a donné ce diagnostic :
Map win32k.sys:
Image region 380:18a280 does not fit in mapping
*** WARNING: Unable to verify timestamp for win32k.sys
*** ERROR: Module load completed but symbols could not be loaded for win32k.sys
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000008E, {c0000005, bf820b78, b91a4710, 0}
Map ACPI.sys:
Image region 300:1af00 does not fit in mapping
Probably caused by : memory_corruption
Followup: memory_corruption
1: kd> !analyze -v
KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003. This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG. This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG. This will let us see why this breakpoint is
happening.
Arguments:
Arg1: c0000005, The exception code that was not handled
Arg2: bf820b78, The address that the exception occurred at
Arg3: b91a4710, Trap Frame
Arg4: 00000000
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - L'instruction "0x%08lx" emploie l'adresse m moire "0x%08lx". La m moire ne peut pas tre "%s".
FAULTING_IP:
win32k+20b78
bf820b78 894024 mov dword ptr [eax+24h],eax
TRAP_FRAME: b91a4710 -- (.trap 0xffffffffb91a4710)
ErrCode = 00000002
eax=000000dd ebx=e108d008 ecx=00000000 edx=bc0570d0 esi=b91a47e8 edi=b91a47f8
eip=bf820b78 esp=b91a4784 ebp=b91a4830 iopl=0 nv up ei pl nz na pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00210206
win32k+0x20b78:
bf820b78 894024 mov dword ptr [eax+24h],eax ds:0023:00000101=????????
Resetting default scope
CUSTOMER_CRASH_COUNT: 4
DEFAULT_BUCKET_ID: CODE_CORRUPTION
BUGCHECK_STR: 0x8E
PROCESS_NAME: Photoshop.exe
LAST_CONTROL_TRANSFER: from bf81f510 to bf820b78
STACK_TEXT:
WARNING: Stack unwind information not available. Following frames may be wrong.
b91a4830 bf81f510 bc0570d0 b91a4898 00000000 win32k+0x20b78
b91a488c bf822257 00000001 00000000 bc0570f2 win32k+0x1f510
b91a48ac bf8fd86f bc0570d0 00000000 00000000 win32k+0x22257
b91a48d0 bf80ea66 bc0570d0 b91a4938 bf80ead3 win32k+0xfd86f
b91a48f8 bf80eb56 00000001 00000001 b91a491c win32k+0xea66
b91a495c 804ddf0f 00020a8a 00000001 0012d490 win32k+0xeb56
b91a495c 7c91eb94 00020a8a 00000001 0012d490 nt!KiFastCallEntry+0xfc
0012d428 00000000 00000000 00000000 00000000 0x7c91eb94
STACK_COMMAND: kb
CHKIMG_EXTENSION: !chkimg -lo 50 -d !win32k
bf820b79 - win32k+20b79
[ 43:40 ]
1 error : !win32k (bf820b79)
MODULE_NAME: memory_corruption
IMAGE_NAME: memory_corruption
FOLLOWUP_NAME: memory_corruption
DEBUG_FLR_IMAGE_TIMESTAMP: 0
MEMORY_CORRUPTOR: ONE_BYTE
FAILURE_BUCKET_ID: MEMORY_CORRUPTION_ONE_BYTE
-ce que j'ai compris que j'ai un problème avec la RAM (jai fais plusieurs passes avec memtest86) mais sans erreurs!!
aidez moi svp car il crash souvent!
MERCI
CM ASRCOK K775S61
P4 LGA 3.0
2*512MO
nvidia fx5200 256MO
Map win32k.sys:
Map ACPI.sys:
1: kd> !analyze -v
happening.
Arguments:
Arg4: 00000000
Debugging Details:
FAULTING_IP:
win32k+20b78
ErrCode = 00000002
win32k+0x20b78:
BUGCHECK_STR: 0x8E
STACK_TEXT:
STACK_COMMAND: kb
[ 43:40 ]
MERCI
CM ASRCOK K775S61
P4 LGA 3.0
2*512MO
nvidia fx5200 256MO
Autres pages sur : ecran bleu probleme memoire
lol sixela t'es parano des alim.
Qu'est-ce que ça va changer? Son PC marchait, et c'est po du tout une erreur provenant de l'alim là...
Soit t'as un processus en cours qui déraille, soit t'as un pilote qui fout la m*****
T'as installé un logiciel ou un matériel récement ?
Ouais je sais, je suis parano des alim' mais j'aime plus du tout le Noname depuis peu de temps, j'aimais déjà pas avant mais j'en mettait quand même dans mes PCs bon marché mais ce temps là est révolu !!!
Je ne veux plus d'alim' Noname nul part !! R&volution !!! En route vers les marques !!! A bas le Noname !!
Sixela39
Sixela39
- ForumRegler probleme ecran bleu
- ForumSabertooth probleme ecran bleu
- ForumProbleme affichage ecran bleu
- ForumProbleme ecran bleu redemarrage
- ForumProbleme ecran bleu portable
- ForumProbleme ordi ecran bleu
- ForumProbleme de ram ecran bleu
- ForumProbleme ecran bleu 0x0000007e
- ForumProbleme skype ecran bleu
- ForumProbleme ecran bleu minidump
