Ecran bleu ....!!!
Salut a tous
j ai recement acheté un laptop a Toshibe satellite L650-108
avec une ATI HD5145
j'ai eu plus de 10 blue screens, lorsque je joue ou j utilise photoshop...
voila le rapport de Whocrached qui analyse les fichiers dump
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Sun 14/11/2010 15:33:30 your computer crashed
This was likely caused by the following module: dxgmms1.sys
Bugcheck code: 0x1000007E (0xC0000006, 0x911CEBB1, 0x8F4709E8, 0x8F4705C0)
Error: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
Dump file: C:\Windows\Minidump\111410-17784-01.dmp
file path: C:\Windows\system32\drivers\dxgmms1.sys
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: DirectX Graphics MMS
The crash took place in a standard Microsoft module. Your system configuration may be incorrect, possibly the culprit is in another driver on your system which cannot be identified at this time.
On Fri 12/11/2010 00:01:35 your computer crashed
This was likely caused by the following module: tunnel.sys
Bugcheck code: 0xD1 (0x1984529, 0x2, 0x8, 0x1984529)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
Dump file: C:\Windows\Minidump\111210-19312-01.dmp
file path: C:\Windows\system32\drivers\tunnel.sys
product: Système d’exploitation Microsoft® Windows®
description: Pilote d’interface de tunnel Microsoft
On Sun 31/10/2010 23:02:17 your computer crashed
This was likely caused by the following module: unknown_image
Bugcheck code: 0x1000008E (0xC0000005, 0x3883271B, 0x8D78F359, 0x0)
Error: KERNEL_MODE_EXCEPTION_NOT_HANDLED_M
Dump file: C:\Windows\Minidump\103110-19968-01.dmp
On Thu 28/10/2010 23:22:13 your computer crashed
This was likely caused by the following module: usbport.sys
Bugcheck code: 0x7F (0x5, 0x0, 0x0, 0x0)
Error: UNEXPECTED_KERNEL_MODE_TRAP
Dump file: C:\Windows\Minidump\102810-19905-01.dmp
file path: C:\Windows\system32\drivers\usbport.sys
description: Pilote de port USB 1.1 & 2.0
On Sun 24/10/2010 13:19:27 your computer crashed
This was likely caused by the following module: ntfs.sys
Bugcheck code: 0x24 (0x1904FB, 0xA5173770, 0xA5173350, 0x830F6EC0)
Error: NTFS_FILE_SYSTEM
Dump file: C:\Windows\Minidump\102410-19656-01.dmp
file path: C:\Windows\system32\drivers\ntfs.sys
description: Pilote du système de fichiers NT
On Wed 06/10/2010 19:21:28 your computer crashed
This was likely caused by the following module: ntkrnlpa.exe
Bugcheck code: 0x19 (0x3, 0x82F4BCE0, 0x825A9D78, 0x40000182)
Error: BAD_POOL_HEADER
Dump file: C:\Windows\Minidump\100610-24663-01.dmp
file path: C:\Windows\system32\ntkrnlpa.exe
description: NT Kernel & System
On Mon 04/10/2010 15:52:18 your computer crashed
Bugcheck code: 0x1 (0x82A72B64, 0x0, 0xE000, 0x0)
Error: APC_INDEX_MISMATCH
Dump file: C:\Windows\Minidump\100410-29250-01.dmp
On Sun 03/10/2010 16:34:10 your computer crashed
Bugcheck code: 0xA (0x3, 0x2, 0x0, 0x82D5674C)
Error: IRQL_NOT_LESS_OR_EQUAL
Dump file: C:\Windows\Minidump\100310-16676-01.dmp
On Sun 03/10/2010 16:25:21 your computer crashed
This was likely caused by the following module: mfeavfk.sys
Bugcheck code: 0xBE (0x93CD8345, 0x6537D101, 0xA3CBD80C, 0xB)
Error: ATTEMPTED_WRITE_TO_READONLY_MEMORY
Dump file: C:\Windows\Minidump\100310-19203-01.dmp
On Sun 03/10/2010 16:17:48 your computer crashed
Bugcheck code: 0xA (0x0, 0xFF, 0x0, 0x82E3ED64)
Dump file: C:\Windows\Minidump\100310-18064-01.dmp
On Sat 02/10/2010 20:34:08 your computer crashed
Bugcheck code: 0x7F (0x0, 0x0, 0x0, 0x0)
Dump file: C:\Windows\Minidump\100210-23587-01.dmp
On Sat 02/10/2010 20:25:13 your computer crashed
Bugcheck code: 0x4E (0x99, 0x0, 0x0, 0x0)
Error: PFN_LIST_CORRUPT
Dump file: C:\Windows\Minidump\100210-26956-01.dmp
On Sat 02/10/2010 11:41:24 your computer crashed
This was likely caused by the following module: mfehidk.sys
Bugcheck code: 0x19 (0x3, 0x853346A8, 0x853340A8, 0x853346A8)
Dump file: C:\Windows\Minidump\100210-17565-01.dmp
On Sat 02/10/2010 11:35:03 your computer crashed
This was likely caused by the following module: hardware
Bugcheck code: 0x24 (0x1904FB, 0x969DB4B8, 0x969DB090, 0x82ACFB68)
Dump file: C:\Windows\Minidump\100210-18564-01.dmp
On Sat 02/10/2010 11:07:40 your computer crashed
This was likely caused by the following module: tcpip.sys
Bugcheck code: 0xD1 (0x3, 0x2, 0x0, 0x8FE96648)
Dump file: C:\Windows\Minidump\100210-17986-01.dmp
file path: C:\Windows\system32\drivers\tcpip.sys
description: Pilote TCP/IP
On Sat 02/10/2010 11:00:35 your computer crashed
This was likely caused by the following module: rtl8192se.sys
Bugcheck code: 0xD1 (0x8DF080, 0x2, 0x1, 0x90EA3768)
Dump file: C:\Windows\Minidump\100210-21294-01.dmp
file path: C:\Windows\system32\drivers\rtl8192se.sys
product: Realtek RTL81892SE Wireless LAN PCI-E NIC
company: Realtek Semiconductor Corporation
description: Realtek RTL81892SE NDIS Driver
J ai remarqué que ma carte graphique etait reconnue come un HD4500 series , et qu elle est overlocké normalement elle est de 1GO , mais la elle a 1,7 GO
SI KELKIN PEUT M AIDER ou a une idée ,cela eviterai bien de gros problemes pour moi ... et merci d'avance
avec une ATI HD5145
Autres pages sur : ecran bleu
il est plus sous garantie?
s'il ne l'est plus, test ta RAM avec Memtest
les pilotes sont tous à jour?
