Bonjour je viens d'avoir un disque dur en s ata 160go , un maxtor diamond max 10, j'ai un autre disque dur branché en IDE qui est en slave, windows est installé sur le disque en s-ata.
J'ai installé ce logiciel : hdd health et depuis peu , j'ai ces erreurs qui se sont s'affichées :
0 16/03/2006 16:15:49 - Program started.
0 16/03/2006 16:15:49 - Total drives found: 3
0 16/03/2006 16:22:43 - Drive0 -
Attribute Seek Time Performance changes from 252 to 253
Attribute Ultra ATA CRC Error Count changes from 115 to 116
1 16/03/2006 16:22:48 - Attribute(s) changes on Maxtor 6Y080P0
0 16/03/2006 16:26:55 - Program closed
0 16/03/2006 16:53:50 - Program started.
0 16/03/2006 16:53:51 - Total drives found: 3
0 16/03/2006 16:53:52 - Drive0 -
Attribute Ultra ATA CRC Error Count changes from 116 to 133
0 16/03/2006 17:03:50 - Program started.
0 16/03/2006 17:03:50 - Total drives found: 3
0 16/03/2006 17:03:50 - Drive0 -
Attribute Ultra ATA CRC Error Count changes from 133 to 143
0 16/03/2006 18:03:50 - Drive0 -
Attribute Ultra ATA CRC Error Count changes from 143 to 149
1 16/03/2006 18:03:55 - Attribute(s) changes on Maxtor 6Y080P0
0 16/03/2006 18:10:27 - Program started.
0 16/03/2006 18:10:27 - Total drives found: 3
0 16/03/2006 18:10:28 - Drive0 -
Attribute Ultra ATA CRC Error Count changes from 149 to 156
0 16/03/2006 18:25:28 - Drive0 -
Attribute Ultra ATA CRC Error Count changes from 156 to 141
0 16/03/2006 18:40:27 - Drive0 -
Attribute Ultra ATA CRC Error Count changes from 141 to 146
1 16/03/2006 18:52:19 - Attribute(s) changes on Maxtor 6Y080P0
1 16/03/2006 18:52:23 - Attribute(s) changes on Maxtor 6Y080P0
0 16/03/2006 19:30:44 - Program started.
0 16/03/2006 19:30:44 - Total drives found: 3
0 16/03/2006 19:30:44 - Drive0 -
Attribute Ultra ATA CRC Error Count changes from 146 to 153
0 16/03/2006 21:30:45 - Drive0 -
Attribute Ultra ATA CRC Error Count changes from 153 to 111
1 16/03/2006 21:30:48 - Attribute(s) changes on Maxtor 6Y080P0
0 16/03/2006 21:45:45 - Drive0 -
Attribute Ultra ATA CRC Error Count changes from 111 to 135
1 16/03/2006 21:54:15 - Attribute(s) changes on Maxtor 6Y080P0
0 16/03/2006 22:00:45 - Drive0 -
Attribute Ultra ATA CRC Error Count changes from 135 to 164
1 16/03/2006 22:03:23 - Attribute(s) changes on Maxtor 6Y080P0
Et je me demande bien ce que peuvent etres ces erreurs et de quel disque dur proviennent elles..
Donc si quelqu'un pouvait m'aider, je le remerci d'avance
Les erreurs proviennent d'un disque Maxtor 6Y080P0, qui est un disque Maxtor Diamond Max Plus 9. Je crois que cela doit être un de tes disques IDE.
Si je comprends bien ta configuration, tu as deux disques Ide et un disque s-ata (qui contient ton système d'exploitation windows).
Je te conseille de télécharger l'utilitaire PowerMax du site de Maxtor et de tester tes disques avec cet utilitaire.
bon je viens de d'essayer de redemarrer avec la disquette contenant PowerMax , le programme de la disquette se lance, me demande d'accepter les chartes etc.. puis bloque a la detection des disques.. Donc je ne sais pas trop quoi faire :s si quelqu'un peut m'aider...
Si tu regardes bien sur le site de Maxtor, pour l'utilitaire PowerMax, on indique que PowermAx ne peut détecter les disques connectés à un controleur Raid ou relié via le chipset NVIDIA Force 4, VIA KT 600 and KT800. Est-ce ton cas (quelle est ta carte mère)?
Si c'est le cas, tu devras tester ton(tes) disques en le branchant dans un système compatible avec powerMax.
Si c'est impossible,Tu peux peut-être te contenter de vérifier tes disques avec l'utilitaire fournis par windows (checkdisk). Dans le poste de travail, cliques vace le bouton de dorite sur ton disque, choisis Propriétés, onglet Outils. Puis tu sélectionnes Vérification des erreurs.
bon he bien voila je vien de verifier le disque, ce qui malheureusement n'a rien changé, esque tu es sur que cette erreur : Attribute Ultra ATA CRC Error Count changes from 135 to 164
provienne bien du maxtor en ide, le mot "ata" dedans m'intrigue assez...
En fait, les disques IDE sont appelés Parallèle ATA (P-ATA), contrairement au disques plus récent sérial ata (S_ATA).
J'ai vu sur un site web que si tu lis le fichier d'aide de hdd health, que ton erreur CRC error count, signifie que le controleur disque après avoir recu l'information du disque dur, effectue un calcul pour vérifier la validité des données qui ont transigés sur le câble du disque. En cas d'erreur (ce qui est ton cas), le contrôleur redemande une nouvelle transmission (cela ralentis le système). Ton erreur peut provenir du disque ou du câble. Est-ce que ton câble est récent (connecteur 40 broches 80 conducteurs au lieu de 40 broches seulement), tel que requis pour les disques récents. Si tu veux tester ton disques avec PowerMax, tu devras peut-être l'installer dans un autre ordinateur.
Vous allez répondre sur un sujet resté inactif pendant plus de 6 mois. Assurez-vous d'apporter des éléments nouveaux à la discussion avant de poursuivre.
