Erreurs SATA
J'ai régulierement des messages d'erreur de mes disque SATA. Par exemple pour aujourd'hui :
19-December-2003 01:14.36 SATARaid Event Logger Started19-December-2003 01:14.36 SATARaid Event writer starting up.
19-December-2003 01:29.47 Warning - Port Error - Aborted
Error ocurred on Secondary Master device on adapter 0. Secondary Master - CDB 28 00 00 69 44 20 00 00 07 00
19-December-2003 01:29.48 Warning - Port Error - Aborted
Error ocurred on Secondary Master device on adapter 0. Secondary Master - CDB 28 00 00 60 64 e0 00 00 07 00
19-December-2003 01:29.49 Warning - Port Error - Aborted
19-December-2003 01:29.50 Warning - Port Error - Aborted
19-December-2003 01:35.31 Warning - Port Error - Aborted
Error ocurred on Secondary Master device on adapter 0. Secondary Master - CDB 28 00 00 0d d5 67 00 00 19 00
19-December-2003 01:35.32 Warning - Port Error - Aborted
19-December-2003 01:36.23 Warning - Port Error - Aborted
Error ocurred on Secondary Master device on adapter 0. Secondary Master - CDB 28 00 00 63 de 00 00 00 07 00
19-December-2003 01:36.28 Warning - Port Error - Aborted
Error ocurred on Secondary Master device on adapter 0. Secondary Master - CDB 28 00 01 16 04 07 00 00 19 00
19-December-2003 19:37.20 SATARaid Event Logger Started
19-December-2003 19:37.20 SATARaid Event writer starting up.
19-December-2003 19:40.21 Warning - Port Error - Aborted
Error ocurred on Secondary Master device on adapter 0. Secondary Master - CDB 28 00 01 19 32 00 00 00 20 00
19-December-2003 19:40.22 Warning - Port Error - Aborted
Error ocurred on Secondary Master device on adapter 0. Secondary Master - CDB 28 00 01 19 31 40 00 00 20 00
19-December-2003 19:40.24 Warning - Port Error - Aborted
Error ocurred on Secondary Master device on adapter 0. Secondary Master - CDB 28 00 01 18 04 6f 00 00 11 00
19-December-2003 19:40.25 Warning - Port Error - Aborted
Error ocurred on Secondary Master device on adapter 0. Secondary Master - CDB 28 00 01 1b 3d 59 00 00 20 00
19-December-2003 19:40.26 Warning - Port Error - Aborted
Error ocurred on Secondary Master device on adapter 0. Secondary Master - CDB 28 00 01 19 33 a0 00 00 20 00
19-December-2003 19:40.28 Warning - Port Error - Aborted
19-December-2003 19:40.29 Warning - Port Error - Aborted
Error ocurred on Secondary Master device on adapter 0. Secondary Master - CDB 28 00 01 19 34 c0 00 00 20 00
19-December-2003 19:57.42 Warning - Port Error - Aborted
Error ocurred on Secondary Master device on adapter 0. Secondary Master - CDB 28 00 02 88 d2 bb 00 00 05 00
19-December-2003 19:57.44 Warning - Port Error - Aborted
Error ocurred on Secondary Master device on adapter 0. Secondary Master - CDB 28 00 02 88 d2 c0 00 00 1b 00
19-December-2003 19:57.55 Error - Device remove
The secondary master on adapter 0, ST3120026AS, was removed.
19-December-2003 19:57.56 Informational - New device
The secondary master on adapter 0, ST3120026AS, is the new device.
J'ai testé mes 2 disk seagate avec l'utilitaire de disque de seagate qui a rien trouvé. J'ai ecahngé les alim et les cables Sata et j'ai encore les mêmes erreurs.
De quoi cela peut il venir ???
Autres pages sur : erreurs sata
Mon RAIDd est pas cassé. Il marche d'ailleur bien la. C'est plutot que j'ai l'impression qu'un de mes disques est injoignable temporairement pendant qq seconde, puis tout revient. D'ailleur comme c ecrit dans le log, a un moment, un disque s'est déconnecté puis est revenu (heureusement que le sata supporte le hot plug). Nempeche que j'ai testé les disques, les alim et les nap sata, tout est ok. A ce demandé si c pas ma carte mére aui déconne (asus A7N7X deluxe acheté en janvier 2003). C'est possible ?
ça me fait penser plus à une anomalie physique sur ta chaine de connexion. Ton alimentation est elle assurée par le ptit adaptateur que fournissent les constructeurs de CM (je veux dire SATA-> IDE)?
Si oui oriente toi vers des pertes de puissance, en gros quand tous tes périphériques consomment simultanément (CG + graveur + lecteurs + USB)
