Mise à niveau de la carte graphique
Merci pour la réponse.
C'est une alim de 375 W et voici toutes les spécification de la machine.Depuis j'ai rajouté de la RAM et je suis maintenant 2GB.
Si tu penses que cette ATI HD 4850 est bien et qu'elle peut supporter mon système et en plus elle un peu moins cher que les autres, alors je l'achèterai.
<< Processor type
Intel® Pentium® 4 Socket-T with Hyper-Threading or Dual-Core support
Cache
1 MB or 2 MB
Memory
Type
dual-channel 400-, 533-, and 667-MHz DDR2
Memory connectors
four
Memory capacities
256 MB, 512 MB, or 1 GB
Minimum memory
512 MB
Maximum memory
4 GB
BIOS address
F0000h
Computer Information
Chipset
Intel 945P
DMA channels
eight
Interrupt levels
24
BIOS chip (NVRAM)
4 Mb
NIC
integrated-network interface capable of 10/100 communication
System clock
800- or 1066-MHz data rate
Video
Type
PCI Express
Audio
Type
internal 7.1 channel or PCI option cards
Expansion Bus
Bus type
PCI 32 bit
PCI Express x1, x4, and x16
Bus speed
PCI 33 MHz
PCI Express 100 MHz
Bus throughput
PCI Express:
x1 slot bidirectional speed — 500 MB/s
x4 slot bidirectional speed — 2 GB/s
x16 slot bidirectional speed — 8 GB/s
PCI
connectors
three
connector size
120 pins
connector data width (maximum)
32 bits
PCI Express
connector
one x1
connector size
36 pins
1 PCI Express lane
PCI Express
connector
one x4
connector size
98 pins
4 PCI Express lanes
PCI Express
connector
one x16
connector size
164 pins
16 PCI Express lanes
Drives
Externally accessible:
two 3.5-inch drive bays (FlexBay)
two 5.25-inch drive bays
Available devices
serial ATA drives (2), floppy drive, USB memory devices, CD drive, CD-RW drive, DVD drive, DVD-RW drive, Media Card Reader, and DVD/CD-RW combo drive
Internally accessible:
two 3.5-inch hard-drive bays
Connectors
External connectors:
IEEE 1394
one front-panel 6-pin serial connector (with optional card)
Video
15-pin VGA connector
28-pin DVI connector
Network adapter
RJ-45 connector
USB
two front-panel and five back-panel USB 2.0-compliant connectors
Audio
five back-panel connectors for line-in, line-out, microphone, surround, and center/Low Frequency Effects (LFE) channel; two front-panel connectors for headphones/microphone
System board connectors:
Primary IDE drive
40-pin connector
Serial ATA
four 7-pin connectors
FlexBay Drive
USB 10-pin header for optional floppy drive or optional Media Card Reader (3.5-inch bay devices)
Fan
two 3-pin and one 5-pin connector
PCI
three 120-pin connectors
PCI Express x1
36-pin connector
PCI Express x4
98-pin connector
PCI Express x16
164-pin connector
Controls and Lights
Power control
push button
Power light
green light — Blinking green in sleep state; solid green for power-on state.
amber light — Blinking amber indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this indicates a problem with the system board (see "Power Lights").
Hard-drive access light
green
Link integrity light (on integrated network adapter)
green light — A good connection exists between a 10-Mbps network and the computer.
orange light — A good connection exists between a 100-Mbps network and the computer.
off (no light) — The computer is not detecting a physical connection to the network.
Activity light (on integrated network adapter)
yellow light — Blinking indicates activity on the network.
Diagnostic lights
four lights on the front panel (see "Diagnostic Lights")
Standby power light
AUXPWR on the system board
Power
DC power supply:
Wattage
375 W
Heat dissipation
1280 BTU/hr
Voltage (See the safety instructions in the Product Information Guide for important voltage setting information.)
90 to 135 V and 180 to 265 V at 50/60 Hz
Backup battery
3-V CR2032 lithium coin cell
Physical
Height
44.45 cm (17.5 inches)
Width
16.764 cm (6.6 inches)
Depth
Weight
12.7 kg (28 lb)
Environmental
Temperature:
Operating
10° to 35°C (50° to 95°F)
Storage
–40° to 65°C (–40° to 149°F)
Relative humidity
20% to 80% (noncondensing)
Maximum vibration:
Operating
0.25 G at 3 to 200 Hz at 0.5 octave/min
Storage
0.5 G at 3 to 200 Hz at 1 octave/min
Maximum shock:
Operating
bottom half-sine pulse with a change in velocity of 20 inches/sec (50.8 cm/sec)
Storage
27-G faired square wave with a velocity change of 200 inches/sec (508 cm/sec)
Altitude:
Operating
–15.2 to 3048 m (–50 to 10,000 ft)
Storage
–15.2 to 10,668 m (–50 to 35,000 ft) >>
Altitude:
Operating
Storage
c'est vrai qu'on y pense jamais, comment je fais si je veux utiliser mon pc en haut du mont blanc???
