Depuis quelques semaines mon pc me met ce message à chaque démarrage : "une panne du disque dur est imminente sauvegardez vos données et remplacer le disque".
Il fonctionne toujours (ralentissement quand même lors d'utilisation de plusieurs applications), mais démarre sans problème.
J'ai fait un test avec diskcheckup.exe. voici le résultat :
DiskCheckup Version: DiskCheckup V2.1 Build: 1001
SmartDisk DLL Version: SmartDisk DLL SDK v1.0 Build: 1013
Time of export: 13:17:30 30-mars-2008
Device ID: 0
Device Capacity: 190779 MB
Model Number: ST3200827AS
Firmware Revision: 3.AHH
Partitions:
C: 183839 MB
D: 6926 MB
IDE Registers:
Features: 0x0
Sector Count: 0x1
Sector Number: 0x1
Cylinder Low: 0x0
Cylinder High: 0x0
Drive Head: 0xA0
Command: 0xEC
ID Sector:
Cylinders: 16383
Heads: 16
Sectors per track: 63
Cur Cyls: 16383
Cur Heads: 16
Cur Sectors/Track: 63
Bytes per track: N.A.
Sectors per track: N.A.
Gen Config: 3162
Buffer Type: 0
Buffer Size: 16384
Vendor Unique: 0 0 0
More Vendor Unique: 0x8010
ECC Size: 4
Double Word IO: 0
Capabilities: 12032
PIO Timing: 512
DMA Timing: 512
BS: 7
Current Sector Capacity: 16514064
Total Addressable Sectors: 268435455
Mult. Sector Stuff: 272
Single Word DMA: 0
Multi Word DMA: 7
SMART ATTRIBUTES:
ID Description Raw Value Status Value Worst Threshold TEC
1 Raw Read Error Rate 64761223 OK 114 100 6 N.A.
3 Spin Up Time 0ms OK 99 98 0 N.A.
4 Start/Stop Count 1380 OK 99 99 20 N.A.
5 Reallocated Sector Count 0 OK 100 100 36 N.A.
7 Seek Error Rate 294260840 OK 84 60 30 N.A.
9 Power On Time 5654 OK 94 94 0 N.A.
A Spin Retry Count 0 OK 100 100 97 N.A.
C Power Cycle Count 110479 FAIL 1 1 20 N.A.
BB (Unknown attribute) 0 OK 100 100 0 N.A.
BD (Unknown attribute) 0 OK 100 100 0 N.A.
BE Temperature Difference from 100 555352097 OK 67 52 45 N.A.
C2 Temperature 33 C OK 33 48 0 N.A.
C3 Hardware ECC Recovered 17360664 OK 64 53 0 N.A.
C5 Current Pending Sector Count 0 OK 100 100 0 N.A.
C6 Uncorrectable Sector Count 0 OK 100 100 0 N.A.
C7 UltraDMA CRC Error Count 0 OK 200 200 0 N.A.
C8 Write Error Count 0 OK 100 253 0 N.A.
CA Direct Address Mark Error Rate 0 OK 100 253 0 N.A.
A priori le problème vient de :
Je ne sais pas exactement ce que c'est. Pouvez vous me dire si mon DD est bon pour la poubelle, combien de temps lui reste t il ou comment corriger ce Power Cycle Count et ne plus avoir de message du SMART.
Il est impossible de savoir combien de temps exactement va durer ton disque. Le système de monitoring SMART permet de prévenir les pannes en observant l'évolution d'un certain nombre de valeurs. Si l'une de ces valeurs dépasse un seuil critique alors un message apparait. Voila. C'est le cas ici. Alors sauvegarde tes données avant la panne et remplace le disque.
