Voici ou j'en suis, vu que ca moulinait...ma souris et clavier sont en USB, je les ai mis directement derriere l'unite centrale, du coup ca a fait son effet, maintenant, j'ai plusieurs options, je te mets tout ce qui s'inscrit sur la page:
completed code age, select functions
NLSFUNC R4.00 national language support
copyright 1988-1998, caldera, inc. coroporation all right reserved.
NW Cache R1.02 Disk cache
copyright 1993-1998 caldera, inc. all rights reserved
copyright 1985,1990,1992, golden bow systems
using DPMS Dos Protected mode services.
Cache size:7670 KB (XMS)
Minimum cache size: 1024 KB
Write-through drives: A B
Current options:
/MLX Program is loaded into conventional and XSM Memory using DPMS
/ BL= 16 Lookahead Buffer is in conventional Memory, size is in KB
/ LEND=ON Lend Memory to other applications-6646kb available
/Delay=OFF Right delay is disable, caching is right-through
Caldera DR-DOS 7.03
Copyright 1976,1998 Caldera inc. All rights reserved
[DR-DOS] A:\> _
