Performances nulles avec 7600 GT
quelqu'un peut-il me dire pourquoi FARCRY2 rame sur mon pc alors qu'il tourne bien sur un autre pc avec le meme ensemble proc+ carte graphique ??
merci d'avance,
SystemInfo version 3.12
Stylesheet version 3.10
CPU Info
Physical Processors 1
Logical Processors 2
CPU 1/1
Intel(R) Pentium(R) 4 CPU 3.00GHz
Manufacturer Intel
Family Intel(R) Pentium(R) 4 CPU 3.00GHz
Architecture 32-bit
Internal Clock 3.0 GHz
Internal Clock Maximum 3.0 GHz
External Clock 200.0 MHz
Socket Designation Socket 478
Type Central
Upgrade ZIF Socket
MultiCore 1 Processor Core
HyperThreadingTechnology Available - 2 HTT Processors per Core
Capabilities MMX, CMov, RDTSC, SSE, SSE2, PAE
Version Intel(R) Pentium(R) 4 CPU 3.00GHz
Caches
Level 1 20 KB
Level 2 512 KB
DirectX Info
Version 9.0c
Long Version 4.09.00.0904
DirectDraw
Version 5.03.2600.5512
Primary Device NVIDIA GeForce 7600 GT
Linked Display Adapters false
Display Device 1/1
NVIDIA GeForce 7600 GT Driver 6.14.11.7824
Description NVIDIA GeForce 7600 GT
Manufacturer NVIDIA
Total Local Video Memory 256 MB
Total Local Texture Memory 240 MB
AGP Aperture Size 512 MB
Driver File nv4_disp.dll
Driver Version 6.14.11.7824
Driver Date 10-7-2008
Driver WHQL Certified true
Max Texture Width 4096 px
Max Texture Height 4096 px
Max User Clipping Planes 6
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Fixed Function Textures In Single Pass 8
Vertex Shader Version 3.0
Pixel Shader Version 3.0
Max Vertex Blend Matrices 0
Max Texture Coordinates 8
VGA Memory Clock 702.0 MHz
VGA Core Clock 561.6 MHz
Max VGA Memory Clock 0.0 Hz
Max VGA Core Clock 0.0 Hz
PCI
Name NVIDIA GeForce 7600 GT
Vendor ID 0x10de
Device ID 0x02e0
SubSystem ID 0x20a3107d
Revision ID 0x00a2
Bus
Type AGP
Revision 3.0
Enabled true
Rate 8
Sideband Addressing Supported
Fast Write Not Supported
Texture Formats
32-bit ARGB [8888]
32-bit RGB [888]
16-bit RGB [565]
16-bit RGB [555]
16-bit ARGB [1555]
16-bit ARGB [4444]
8-bit A [8]
8-bit YUV [800]
16-bit AYUV [8800]
FourCC [DXT1]
FourCC [DXT2]
FourCC [DXT3]
FourCC [DXT4]
FourCC [DXT5]
Capabilities
AGP Texturing, Hardware Transform and Lighting, Positional Lights, Subpixel Accurate Rasterizing, Stencil Buffers, Range Fog, Table Fog, Vertex Fog, W-Fog, Specular Gouraud Shading, Anisotropic Filtering, Bilinear Filtering, Point Sampling, Trilinear Filtering, Additive Texture Blending, Dot3 Texture Blending, Multiplicative Texture Blending, Subtractive Texture Blending, Environmental Bump Mapping, Environmental Bump Mapping With Luminance, Cube Mapping, Factor Alpha Blending, Vertex Alpha Blending, Texture Alpha Blending, Texture Clamping, Texture Mirroring, Texture Wrapping, Guard Band Support, Mipmap LOD Bias Adjustment, Projected Textures, Volume Textures, Point Primitive Support, Full-Screen Anti-Aliasing, DXT Compressed Textures, Two Sided Stencil Test, Mipmapped Volume Textures, Mipmapped Cube Textures, Texture Border Color, Spherical Mapping, Automatic Mipmap Generation, Hardware Rasterization, Shading, Transform and Lighting, Scissor Test, Legacy Depth Bias
DirectShow
Version 9.0c
Registered DirectShow Filters
.RAM file Parser
AC3 Parser Filter
AC3File
AC3Filter
ACELP.net Sipro Lab Audio Decoder
ACM Wrapper
ASF ACM Handler
ASF DIB Handler
ASF DJPEG Handler
ASF ICM Handler
ASF JPEG Handler
ASF URL Handler
ASF embedded stuff Handler
ASX file Parser
ASX v.2 file Parser
AVI Decompressor
AVI Draw
AVI Splitter
AVI/WAV File Source
Avi Source
Avi Splitter
Color Space Converter
CoreVorbis Audio Decoder
CyberLink Video/SP Decoder (PDVD8)
DC-Bass Source
DV Muxer
DV Splitter
DV Video Decoder
Decrypt/Tag
Default DirectSound Device
Default MidiOut Device
DirectVobSub (auto-loading version)
FLV Source
FLV Splitter
FLV4 Video Decoder
File Source (Async.)
File Source (Monkey Audio)
File Source (Netshow URL)
File Source (URL)
File stream renderer
Haali Media Splitter
Haali Media Splitter (AR)
Indeo audio software
Indeo video 4.4 Decompression Filter
Indeo video 5.10 Decompression Filter
Internal Script Command Renderer
Line 21 Decoder
Line 21 Decoder 2
MIDI Parser
MJPEG Decompressor
MONOGRAM AMR Decoder
MONOGRAM AMR Encoder
MONOGRAM AMR Mux
MONOGRAM AMR Splitter
MONOGRAM Musepack Decoder
MONOGRAM Musepack Splitter
MP4 Source
MP4 Splitter
MPEG Audio Decoder
MPEG Layer-3 Decoder
MPEG Video Decoder
MPEG-2 Demultiplexer
MPEG-2 Sections and Tables
MPEG-2 Splitter
MPEG-I Stream Splitter
MPEG4 Video Source
MPEG4 Video Splitter
Microsoft MPEG-4 Video Decompressor
Microsoft Screen Video Decompressor
Mpeg Splitter
Multi-file Parser
NSC file Parser
Overlay Mixer2
QT Decompressor
QuickTime Movie Parser
RealAudio Decoder
RealMedia Source
RealMedia Splitter
RealVideo Decoder
SAMI (CC) Parser
VBI Surface Allocator
VGA 16 Color Ditherer
VP6 Decompressor
VP7 Decompressor
Video Port Manager
Video Renderer
WM ASF Reader
WM ASF Writer
WST Decoder
WavPack Audio Decoder
WavPack Audio Splitter
Wave Parser
Windows Media Audio Decoder
Windows Media Multiplexer
Windows Media Update Filter
Windows Media Video Decoder
Windows Media source filter
XML Playlist
ffdshow Audio Decoder
ffdshow Video Decoder
madFlac Decoder
madFlac Source
DirectSound
Version 5.3.2600.5512
Speaker Configuration Stereo
Speaker Geometry Wide
Primary Device Realtek AC97 Audio
Sound Device 1/1
Realtek AC'97 Audio Driver 5.10.0.6160
Description Realtek AC97 Audio
Manufacturer Realtek
Driver File ALCXWDM.SYS
Driver Version 5.10.0.6160
Driver Date 8-18-2006
Max Supported 3D Hardware Sounds 26
HD Audio Support false
EAX Support Supported
PCI
Name Realtek AC'97 Audio
Vendor ID 0x1039
Device ID 0x7012
SubSystem ID 0xe0091631
Revision ID 0x00a0
Capabilities
Continuous Rate, Primary Buffer with 16-bit Samples, Primary Buffers with 8-bit Samples, Monophonic Primary Buffers, Stereo Primary Buffers, Hardware-mixed Secondary Buffers with 16-bit Samples, Hardware-mixed Secondary Buffers with 8-bit Samples, Hardware-mixed Monophonic Secondary Buffers, Hardware-mixed Stereo Secondary Buffers
Memory Info
Total Physical Memory 2.00 GB
Free Physical Memory 1.58 GB
Total Pagefile Memory 3.85 GB
Free Pagefile Memory 3.59 GB
Memory Array 1/1
Max Module Capacity 2.00 GB
Supported Speeds -
Supported Types -
Supported Voltages -
Memory Slot 1/2
Installed Enabled Size 1.00 GB
Form Factor DIMM
Frequency 400.0 MHz
Slot <conversion error>
Manufacturer <conversion error>
Type Details -
Total Bit Width 64 b
Data Bit Width 64 b
Memory Slot 2/2
Form Factor DIMM
Frequency 400.0 MHz
Type Details -
Data Bit Width 64 b
Motherboard Info
Supported Slot Types ISA, PCI, AGP
Manufacturer NEC COMPUTERS INTERNATIONAL
Model PAROS - GA-8S648FXM2-P-NF
BIOS Vendor Award Software International, Inc.
BIOS Version F8
BIOS Release Date 03/22/2004
BIOS Properties Plug and Play, Flash, AGP
AGP
Revision 3.5
Rate 4x, 8x (8x enabled)
Available Rate 0x0000000c
Selected Rate 0x00000008
Aperture Size 0 B
Sideband Addressing Supported (enabled)
Fast Write Supported (disabled)
PCI Devices
Processeur SIS vers contrleur AGP
Manufacturer Silicon Integrated Systems
Location Bus PCI 0, priphrique 1, fonction 0
Pont PCI vers ISA SIS
Location Bus PCI 0, priphrique 2, fonction 0
Pont CPU hte standard PCI
Manufacturer (Priphriques systme standard)
Location Bus PCI 0, priphrique 0, fonction 0
Contrleur SiS PCI IDE
Location Bus PCI 0, priphrique 2, fonction 5
Contrleur d'hte ouvert PCI vers USB SiS 7001
Location Bus PCI 0, priphrique 3, fonction 0
Location Bus PCI 0, priphrique 3, fonction 1
Location Bus PCI 0, priphrique 3, fonction 2
Contrleur hte tendu PCI vers USB SiS
Location Bus PCI 0, priphrique 3, fonction 3
Contrleurs hte IEEE 1394 compatible OHCI
Manufacturer Fournisseur de contrleur hte IEEE 1394 compatible OHCI
Location Bus PCI 0, priphrique 2, fonction 3
Realtek AC'97 Audio
Location Bus PCI 0, priphrique 2, fonction 7
Smart Link 56K Voice Modem
Manufacturer Smart Link (www.smlink.com)
Location Bus PCI 0, priphrique 2, fonction 6
Manufacturer NVIDIA
Location Bus PCI 1, priphrique 0, fonction 0
Carte rseau Fast Ethernet PCI Realtek RTL8139 Family
Location Bus PCI 0, priphrique 15, fonction 0
Contrleur multimdia
Location Bus PCI 0, priphrique 10, fonction 0
Card Slots
PCI Slot
Order 9
Designation PCI1
Type PCI
Characteristics 5.0V, PME Signal
Data Bus Width 32 b
Details -
IRQ 0
PCI Slot
Order 10
Designation PCI2
Type PCI
Data Bus Width 32 b
Details Available
IRQ 0
PCI Slot
Order 11
Designation PCI3
Type PCI
Data Bus Width 32 b
Details -
IRQ 0
AGP Slot
Order 0
Designation AGP
Type AGP
Data Bus Width 32 b
Details Available
IRQ 0
Slot
Order 13
Designation CNR
Data Bus Width 16 b
Details Available
IRQ 0
System Devices
Name Processeur SIS vers contrleur AGP
Name Pont PCI vers ISA SIS
Name Pont CPU hte standard PCI
USB Devices
Description Concentrateur USB racine
Driver Date 7-1-2001
Driver Version 5.1.2600.2180
Device Class Universal Serial Bus Controller
Description Priphrique d'interface utilisateur USB
Device Class Human Interface Device
Description Priphrique de stockage de masse USB
Driver Version 5.1.2600.0
FireWire Devices
Description Carte rseau 1394
Driver Version 5.1.2535.0
Device Class Network Adapter
Monitor Info
Monitor 1/1
Name Acer AL17xx
Manufacturer Acer Incorporated
Max Width 1280 px
Max Height 1024 px
Operating System Info
Name Microsoft Windows XP
Version 5.1.2600
PlatformId 2
Service Pack Service Pack 3 (v3.0)
Suite 768
Product Type 1
Media Center false
Windows Environment 32-bit
Locale FR
Desktop Width 1024 px
Desktop Height 768.000000000 px
Desktop BPP 32 b
Internet Explorer Version 75730
DEP
Hardware Support false
Applications Protected false
Drivers Protected false
User Option On for essential Windows programs and services only
Autres pages sur : performances nulles 7600
alim: 180w continue, 450W max marque TOPELITE.
aujourd'hui :
DRIVER NVIDIA 181.22 pour XP 32BITS (drivers à jour) = pb d'affichage.
Passage sur ts les drivers.com, légère améliorations avec les drivers 178.24. mais perte de l'image dans les jeux avec les drivers 181.20 et 181.22.
Le bureau ainsi que les logiciels de bureautique fonctionnent mais dès le lancement d'un jeu l'écran devient noir. Lorsque je promène la souris sur l'écran de half life, j'entends que le pointeur passe sur les options du menu mais rien ne s'affiche.
NFS undercover et far cry 2 en 800x600 "rament". Toutes les options graphiques au min.
Merci pour vos réponses,
'est aussi ce que j'ai pensé au vu des remarques sur le fabricant de mon alim.
Finalement après avoir beaucoup chercher sur les forums, j'ai trouvé une option du bios: AGP aperture size.
Je l'ai réduite à 256 et depuis pas mal d'applic. refonctionnent.
Qui peut me dire à quoi ça sert et comment la paramétrer ??
merci,
Je m'incruste dans le topic à l'instant :D
Ok pour l'alim TOPELITE ça tient rien c de la m**** mais bon tout ne vient pas d là, NFS comme je l'ai dit dans un topic c'est une bouse et même avec une 7600gt ça aurait du tourner correct mais bon....EA stagière Inside!!
Pour Farcry 2 je conçoit que ça soit pas suffisant mais si la même config tourne mieux faut voir. Je suis assez réservé car je ne pense quand même pas que ça tourne si bien que ça et je trouve normal que tu es des soucis déjà au niveau global de ta config c'est même pas que c'est limite car les P4 rendent encore de beaux services, mais c'est pas optimisé pour ce genre de jeux. Je ne parle même pas de l'architecture qui existait à l'époque sur les CG rien que le mode de traitement doit te bouffer le framerate.
Cela dit pour résoudre ton problème teste avec une vraie alim et la différence peut-être déjà cachée dans des tensions impuissantes qui oscillent trop bas, mais sincèrement ça restera limite pour ce genre de jeux et surtout d'optimisation... :ange:
Merci pour vos réponses !!
Effectivement ma config date, mais bon à moins de gagner au loto...
Néanmoins, en passant l'agp aperture size de 512 à 256, Far cry tourne en 1024x768 et nfs également.
Acheter un pc en grande surface apporte au moins une chose: à force de bidouiller en permanence dessus pour le faire fonctionner, on apprend plein de "trucs" !!!!
J'espère pouvoir bientôt étaler une config d'enfer sur ce forum très sympa !!!!
Merci encore...
