pouvez m'aider
Puissance et marque de l'alim aussi ; c'est important dans ce genre de cas ( je dis la marque parce que les nonames n'ont pas souvent les watts annonçés ! )
Ce forum te permet d'afficher ta config dans ton profil : on gagne beaucoup de temps !
j'ai une alim 300 W mais la n'est pas le prob car le ventilo de la carte marche
pour ma carte mere :
PROCESSORS
Socket 478 supports the
Intel® Pentium® 4 processor, up to 400MHz FSB
CHIPSET
VIA® P4X266A & VT8233
P4X266A V-Link Host system controller and VT8233 V-Link Client to PCI/LPC bridge
Peak Bandwidth 266MB/S 8-bit V-link Host Controller
LPC I/O: ITE8705F
System Hardware Monitor: Integrated in ITE8705F
LAN: MAC Integrated in VT8233 & PHY on board (optional)
AC97 Audio Codec
Compliant with AC97 2.1 specification
SYSTEM BIOS
AMI 2Mb Flash EEPROM
Supports Plug and Play 1.0A, AMP 1.2, Multi Boot, DMI
Support for ACPI revision 1.0 specification
MEMORY
2 DDR DIMM sockets and 2 DIMM sockets support (can not be used simultaneously)
Two 184-pin 2.5V DDR SDRAM (DDR266/DDR200) or
Two 168-pin 3.3V SDRAM (PC133/PC100)
Maximum: 2GB DDR or SDRAM (Buffered) / 1GB DDR or SDRAM (Unbuffered)
I/O INTERFACE
Supports Plug and Play function
PS/2 keyboard and PS/2 mouse connectors
Dual USB Ports and an optional LAN connector
One - EPP/ECP mode parallel port
Two - 16550 high-speed serial I/O ports
Audio Ports (Line-in, Line-out, Mic-in, CD-in and game port)
Dual PCI IDE interfaces - support four IDE devices (PIO mode 4, DMA Mode 2, Ultra DMA 66/100)
Supports 360K~2.88M Byte, 3 Mode FDDs or LS120
ATX Power Supply Connector
Ports, Headers and Others:
IrDA header
Front Panel MIC/Line-Out header
Four Extra USB Ports (USB1 and USB2)
HDD LED, ACPI MSG LED, Reset Switch, Power Switch headers
CPU and Case Fan headers
LAN Card Wake Up/Internal Modem Ring Wake Up headers
RTC & BATTERY
VT8233 included 256 bytes of CMOS
With CMOS hardware clear jumper
EXPANSION SLOTS
4 PCI slots, 1 AGP slot, 1 CNR slot
FORM FACTOR
ATX (305mm*244mm), 4 Layers
Ou tu as de l'humour ou on s'est pas bien compris ; je parlais de ta config pas de dépliant constructeur !
Donc on ne sais toujours pas si tu as une noname avec x disques durs , x lecteurs , x pci etc ....???
Le ventilo qui tourne , ça ne veut rien dire , il lui faut très peu de jus , par contre un chip de carte graphique actuelle , c'est plus gourmant .
J'insiste pas ; essaye seulement de débrancher quelques périphériques et tu en auras le coeur net .
