Quelle carte garaphique ??
je voudrais acheter une carte graphique si possible "HD" (comme mon ecran)
mais jai un budget limité a 50/60 euros et jaimerais surtt savoir "Laquelle" choisir par rapport a ma config ...
Pourriez vous m'orienter ??
Voici ma config PC
Plugin version 3.1.2 build 0
Base version 9
Detection Date 24/03/2009 16:13
Hostname PC win-6f92e3b44cd
Operating System Windows XP Home Edition (build 2600) Service Pack 3
Default web client: Internet Explorer
Default email client: Microsoft Office Outlook
Default newsgroup client: Outlook Express
Antivirus: avast! antivirus 4.8.1335 [VPS 090323-0] 4.8.1335
Motherboard SMBios version 2.3
Foxconn P4M800P7MB
Bios: Phoenix Technologies, LTD 6.00 PG 07/28/2006 taille: 512Kb
Chipset North bridge: VIA CN700
South bridge: VIA VT8237/R
Processor Intel(R) Pentium(R) 4 CPU 2.80GHz (2788Mhz) (L1: 28ko L2: 2048ko )
Memory Memory Chip 1024 Mo None
Memory Chip 512 Mo None
Windows memory (This value doesn't match with the physical memory):
1470Mo
Graphic card VIA Technologies, Inc. CN700/P4M800 Pro/P4M800 CE/VN800 [S3 UniChrome Pro] (64
Mo)
IDE devices Hitachi HDS721616PLAT80 P22OA60A (ATA, 153.39 Go, tampon: 7 Mo)
CDRom TSSTcorpCDDVDW SH-S222A SB00 (DVD-R/DL sequential recording Recorder)
ZYPEFWR 3W5EJO9U 1.03
Harddrive Hitachi HDS721616PLAT80
Myson CS8819A2-105 00 USB Device
Myson CS8819A2-105 10 USB Device
Myson CS8819A2-105 20 USB Device
Myson CS8819A2-105 30 USB Device
WD 5000AAC External USB Device
PCI/AGP cards Mass storage
VIA Technologies, Inc.:VIA VT6420 SATA RAID Controller
VIA Technologies, Inc.:VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE:
VT82C586/B/VT82C686/A/B/VT8233/A/C/VT8235 PIPC Bus Master IDE
Network
Realtek Semiconductor Co., Ltd.:RTL-8139/8139C/8139C+
Display
VIA Technologies, Inc.:CN700/P4M800 Pro/P4M800 CE/VN800 [S3 UniChrome Pro]
Multimedia
C-Media Electronics Inc:CM8738: CMI8738/C3DX PCI Audio Device
VIA Technologies, Inc.:VT8233/A/8235/8237 AC97 Audio Controller
Bridge
VIA Technologies, Inc.:CN700/VN800/P4M800CE/Pro Host Bridge
VIA Technologies, Inc.:CN700/VN800/P4M800CE/Pro Host Bridge:
T890 Host Bridge: PT890 Host Bridge
VIA Technologies, Inc.:VT8237/VX700 PCI Bridge: VT8237/VX700 PCI Bridge
VIA Technologies, Inc.:VT8237 ISA bridge [KT600/K8T800/K8T890 South]: DFI
KT600-AL / Soltek SL-B9D-FGR Motherboard
Serial bus
VIA Technologies, Inc.:VT82xxxxx UHCI USB 1.1 Controller
VIA Technologies, Inc.:USB 2.0
Keyboard Clavier standard 101/102 touches ou clavier Microsoft Natural Keyboard PS/2
Mouse Souris compatible PS/2
Screens Écran Plug-and-Play(Samsung SAMSUNG)
MERCI DAVANCE
Voici ma config PC
Base version 9
Foxconn P4M800P7MB
1470Mo
Mo)
Network
Display
Multimedia
Bridge
T890 Host Bridge: PT890 Host BridgeVIA Technologies, Inc.:CN700/VN800/P4M800CE/Pro Host Bridge:
Serial bus
MERCI DAVANCE
Autres pages sur : carte garaphique
c'est quoi ton écran?
une HD3650 serra le maximum au vue de ton CPU, mais donne la puissance et la marque de ton alim(c'est marqué dessus)
lemathos a dit :
Sachant que ta carte mere ne prend que l'AGP t'attend pas a des performance terrible. Il commence un peu a dater ton ordi quoi
cad...
Quentend tu par pas terrible ?? C'est sur qu'il a maintenant 3ans au moins... Mais pense tu que je peu encore le mettre a jour pour pas cher??
Ou alors tu me conseillerai den racheter un (ce qui me reviendrai moin cher?)
thor37230 a dit :
c'est quoi ton écran?une HD3650 serra le maximum au vue de ton CPU, mais donne la puissance et la marque de ton alim(c'est marqué dessus)
Hello mon ecran samsung noir laqué HD ready
mon alim c'est marqué AC 230V
Après la marque... Je sais pas
thor37230 a dit :
Je crois que c'est mort pour cette carte mon alim ne fait que 305 W
faudra changer aussi d'alim
dans ce cas tu peux te diriger vers une carte graphique un peu moins puissante que la HD3650 et prendre une bonn alim, mais quoi qu'il en soit on sera au dessus de ton budget
X1650 Pro 512Mo AGP
Corsair CX 400W
X1650 Pro 512Mo AGP
Corsair CX 400W
thor37230 a dit :
faudra changer aussi d'alimdans ce cas tu peux te diriger vers une carte graphique un peu moins puissante que la HD3650 et prendre une bonn alim, mais quoi qu'il en soit on sera au dessus de ton budget
X1650 Pro 512Mo AGP
Corsair CX 400W
merci sympa !!
je pense que je vai fair ca
mais par contre j'ai été très surpris par le prix de lalim corsair !!!
ce nest pas un peu cher j'ai vu des 480w chez ldlc a 30 euros...
il faut peut etre en prendre une de bonne qualité "oblige" ??
Merci en tous cas, jvai prendre cet carte
thor37230 a dit :
X1650 Pro 512Mo AGP
Corsair CX 400W
Pendant que jy suis...
Quest ce que tu changerais sur mon PC ??
jregardais les pack processeur... Pense tu que ca vau le coup que jinvestisse un peu dans mon pc ??
je connais pas l'état de tes finances, mais si tu peux garder ton fric pour changer de config(CM+Proc+CG+Alim+RAM+DD+éventuellement boitier+graveur DVD+système d'exploitation) ce serait bien plus bénéfique, parce que là faut tout changer si tu veux jouer au jeux récent(à moins que tu ne veuille pas jouer au jeux récent)
thor37230 a dit :
whaou..Alors ca me parait beaucoup... Je ne suis pas super calé mais qd meme je me pose la question ?? Pourquoi changer de "graveur" "boitier" "ram.." ou meme system exploit
. POURQUOI CHANGER TOUS CA ?Sachant que "OUI" je suis pret a renoncer a jouer, sachant que ce que je fait le + c'est du multimedia, jvoulais une très bonne image sur mon ecran et une bonne fluidité de naviguation, J'ai une ps3 dc les jeux c'est pas très grave... jregarde des fims et je surf.
- ForumQuelle carte son pour les z 680
- ForumQuelle carte son pour mes z680
- ForumQuelle carte pour crossfire
- ForumQuelle carte son pour de lenregistrement
- ForumQuelle carte son pour mao
- articlesQuelle carte am3
- ForumQuelle est ma carte son mac
- articlesQuelle carte pour physx
- ForumQuelle carte mere entre ces 4
- ForumQuelle carte video acheter
