Bonjour a tous,
j ai un probleme !
ce fameux ecran bleu apparait quand je joue a cod 4 et dernierement sacred 2
j avais parfaitement reformate le pc il y a 2 semaines, il tournait tres bien mais apres le bosd avec sacred 2 c est la cata !
il me faut 2 minute pour que windows se lance, 30 secondes pour un film sur vlc.
j ai pris le fichier dump et l ai analyser avec windbg et voila le resultat :
CRITICAL_OBJECT_TERMINATION (f4)
A process or thread crucial to system operation has unexpectedly exited or been
terminated.
Several processes and threads are necessary for the operation of the
system; when they are terminated (for any reason), the system can no
longer function.
Arguments:
Arg1: 00000003, Process
Arg2: 89fab1c0, Terminating object
Arg3: 89fab334, Process image file name
Arg4: 8060566e, Explanatory message (ascii)
Debugging Details:
PROCESS_OBJECT: 89fab1c0
IMAGE_NAME: hardware_disk
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAULTING_MODULE: 00000000
PROCESS_NAME: csrss.exe
EXCEPTION_RECORD: f75259d8 -- (.exr 0xfffffffff75259d8)
ExceptionAddress: 75b200d1
ExceptionCode: c0000006 (In-page I/O error)
ExceptionFlags: 00000000
NumberParameters: 3
Parameter[0]: 00000000
Parameter[1]: 75b200d1
Parameter[2]: c000009d
Inpage operation failed at 75b200d1, due to I/O error c000009d
EXCEPTION_CODE: (NTSTATUS) 0xc000009d - STATUS_DEVICE_NOT_CONNECTED
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: DRIVER_FAULT
ERROR_CODE: (NTSTATUS) 0xc0000006 - L'instruction "0x%08lx" emploie l'adresse m moire "0x%08lx". Les donn es n cessaires n'ont pas t plac es en m moire en raison d'un tat d'erreur d'E/S de "0x%08lx".
IO_ERROR: (NTSTATUS) 0xc000009d - STATUS_DEVICE_NOT_CONNECTED
EXCEPTION_STR: 0xc0000006_c000009d
FAULTING_IP:
+75b200d1
75b200d1 ?? ???
BUGCHECK_STR: 0xF4_IOERR_C000009D
FOLLOWUP_IP:
+75b200d1
75b200d1 ?? ???
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: hardware_disk
STACK_COMMAND: kb
FAILURE_BUCKET_ID: 0xF4_IOERR_C000009D_IMAGE_hardware_disk
Followup: MachineOwner
Seulement voila quelqu un peut il decrypter ca ???!!!
j ai lu quelques articles sur le processus csrss mais je voispas vraiment ce que je dois faire
Toutes aides serai la bienvenue !!
merci a vous
