[Topic unique] CDburnerXPpro & DeepBurner : gravons gratuitement !
je m'aperçois que bien que plusieurs fois cités dans divers topics, ces deux superbes logiciels restent très peu connus, pourtant sont de tres bonne facture, ils peuvent remplacer aisement un nero express, et font jeu egal sur certains point avec nero burning, vont meme jusqu'a proposer des outils inexistants sur ce dernier (notamment la dropbox de cdburner)
CDBurnerXP pro :
http://www.cdburnerxp.se/
* burn any Data on CD-R/CD-RW/DVD+R/DVD-R/DVD+RW/DVD-RW
* burn mp3-CDs to store many audio files on one single disc
* burn Video-DVDs with menus (read in helpfile how to do that)
* create bootable discs
* verify written Data automatically after burning process
* use either the internal browser to add your files or the intuitive Drop-Box to drag and drop files directly from any Windows Explorer window
* apply file filters to see only the files you need (for example *.jpg to display only JPEG files in local browser)
* save your compilations for creation of backups
* burn on-the-fly and with buffer-underrun protections
* import previous (ISO 9660) sessions and edit existing file structure on CD/DVD
* quick- and full-erase disc
* retrieve recorder and disc information
* overburning possible
Create Audio-CDs
* create Audio-CDs from mp3, wav, ogg and wma* files
* add single or multiple tracks from existing audio-CDs directly to your new compilation without ripping tracks before (add cda-files)
* play audio-files with integrated audio player
* gapless audio-CDs supported (disc-at-once-mode)
* import m3u-playlists
* integrated advanced audio editor
* *only available for Win98SE and later
Rip Audio-CDs
* rip tracks from any audio-CD to wav, mp3, wma or ogg
* download album information from online database
* sort ripped files in subdirectory automatically (based on information you get from online database)
* supports jitter-correction ripping modes to rip tracks from scratched CDs
ISO features
* burn ISO files to CD
* create your own ISO files
* convert bin- and nrg-files to ISO
Other features
* simple cover printing feature for Data- and Audio-CDs
* Audio Editor
* MP3 Tag-Editor
* converter for audio files (wav+mp3)
* supports most IDE, USB, Firewire and SCSI drives
* ASPI not required for NT/2000/XP
* integrated option to enable access to drive for restricted users
* lots of settings to customize CDBurnerXP Pro
* multi-language interface
* online update
DeepBurner
http://www.deepburner.com/
* Ability to create and burn regular data CDs/DVDs
* AudioCD recording functionality
* Burn and Build ISO Images
* Support for IDE/EIDE, USB, SCSI, Fire wire CD/DVD Writers
Burning Features
* Overburn function
* Buffer underrun technology "Burn-Proof"
* DAO, SAO and TAO Writing methods support
* Support for CD-R / CD-RW / DVD-R / DVD-RW / DVD-RAM / DVD+RW
* Create Multi-session CDs
* Write on Rewritable CDs/DVDs
* Bootable CD/DVD support
Specific Features
* Dynamically adjustable drive buffer size
* High Performance File/Disc Caching
* Support Long File Name ( Joliet ) File System
* Create ISO (100% DOS/Windows) compatible Data CDs / DVDs
* Support for multiple simultaneous recorders
Ease of Use and Compatibility
* Easy to use wizards help you with creation of any type of burning projects
* Autorun making wizard makes it easy to create effective autoruns for your CDs
* Features covers/booklet/case insert making wizard
* Multi-language interface
Burn4Free :
http://www.burn4free.com/
2. Low cost burning : you can burn and dvd copy- backup data - cd with only 2 clicks
3. CD-R/CD-RW/DVD-R/DVD+R/DVD-RW/DVD+RW/DVD-RAM drives (SCSI - IDE/EIDE - USB) are supported
4. Multi languages: few languages are available, choose your favorite
5. Print Compilation, select layout, colors and items to print
6. 4 way to burn your CD/DVD: you can choose the way you prefer to burn a CD/DVD (fly window, right click from explorer, internal add window, derag & drop
7. Burn and save .ISO files
8. DVD dual layer support (check Compatibility menu)
9. Print Compilation
10. Burn MP3 compilation
11. Free online upgrades
12. Easy Interface
13. Easy to use ex: you can store all your movies
14. 1900 + COMPATIBLE RECORDERS
Microburner
http://www.silentnight2004.com/microburner.html
shareware, mais illimité dans le temps, seules certaines options se retrouvent grisées
Create Data-CDs/DVDs* burn any Data on CD-R/CD-RW/DVD+R/DVD-R/DVD+RW/DVD-RW
Create Audio-CDs
Rip Audio-CDs
ISO features
Other features
* Audio Editor
* MP3 Tag-Editor
* online update
Main Features* Ability to create and burn regular data CDs/DVDs
Burning Features
* Overburn function
Specific Features
1. Burn4Free burn data (CD and DVD) and audio from different files types (WAV, FLAC, WavPack, WMA, M3U (mp3 winamp compilation) , MP3, MP2, MP1 OGG and CDA (normal cd audio tracks))2. Low cost burning : you can burn and dvd copy- backup data - cd with only 2 clicks
12. Easy Interface
Autres pages sur : topic unique cdburnerxppro deepburner gravons gratuitement
Le site http://www.cdburnerxp.se/ pour CDBurnerXP pro est mort
J'ai pu le trouver : http://www.google.fr/search?hl=fr&q=CDburnerXP+pro&btnG...
bonjour, besoin d'un petit coup de main...
je grave avec cd burner depuis plusieurs mois : nickel. J'ai un lecteur-graveur pioneer.
Mais depuis 1 semaine il ne grave plus les films ?
Des données de boulot et cd audio :nickel.
Les divx, tout semble se passer correctement (mêmes étapes de gravure que précedemment) mais il ne veut pas les lire ensuite ? Il lit sans problème ceux que j'ai gravé il y a plus longtemps.
Visiblement le cd est plein mais aucun fichier n'apparait.
J'ai désinstallé et reinstallé cd burner.
et j'ai pas d'autre d'idée...
merci
merci
casacool06 a dit :
bonjour, besoin d'un petit coup de main...je grave avec cd burner depuis plusieurs mois : nickel. J'ai un lecteur-graveur pioneer.
merci
tu fais un cd de données ?
J'ai absolument rien changer
Sauf que j'ai gravé un 800mb et qu'il a pas voulu me le lire (avec un petit tac-tac mécanique désagréable)
Et je crois bien que c'est depuis qu'il merde
c'est grave docteur???
Le lendemain : désolée d'encombrer ce topic ça n'a rien à voir avec cdburner, c'est moi qui l'ai flingué a vouloir gravé du 800 malgré les déconseils avisés. Grave très bien même les divx quand je suis inférieur à 650 mais dès que je fraule 700 veut plus rien savoir.
I am a grosse daube têtue
casacool06 a dit :
Normalement, pour des fichiers jusqu'a 715mo ça passe en overburn sur cdr de 700, au-dela, il faut des cdr 800.
PS: Bien sûr s'assurer que le graveur en soit capable avant.
PS2 : Utiliser Nero CD/DVD Speed : test de gravure en surcapacité.
Un petit lien explicatif ici
j'ai trouvé celui la.
Je le trouve super facile d'utilisation.
Free Easy CD DVD Burner
http://www.01net.com/telecharger/windows/Utilitaire/gra...
a tester
a tester
- ForumTopic unique power metal
- articlesTopic unique galaxy tab
- ForumTopic unique matrox parhelia
- ForumTopic unique panasonic fz7
- ForumTopic unique des programmes de la tnt
- benchmarkTopic unique 3dmark vantage
- ForumTopic unique comment dã bloquer un tã lã phone
- ForumTopic unique bios 1014
- ForumTopic unique matrix reloaded
- ForumManga topic unique
